Author Topic: 98 1998 Sport 1100 FS For Sale Craigslist CL, unknown problems  (Read 18440 times)
Offline Turin
Re: 98 1998 Sport 1100 FS For Sale Craigslist CL, unknown problems
« Reply #60 on: April 14, 2016, 05:17:10 PM »
The fairing wasn't broken, it was cut very cleanly, so a patch should be super easy. I'd still wage it won't start because of an electrical issue. BTW, I offered
$1,700 for her.
1986 Sidlow Guzzi
1996 Triumph Daytona 900
Offline dsrdave
« Reply #61 on: April 14, 2016, 06:18:19 PM »
I paid just a touch more.  I don't anticipate any major problems.  A major service, fix the fuel pump issue and repair the fairing.  It gives me a project while I'm in Vegas and keeps me out of the casinos......
« Reply #62 on: April 15, 2016, 03:58:04 AM »
Take the fuel pump off.  Spray carb cleaner into both ends.  Drain.  Look down into it.  If your lighting is good enough you'll see a rotor.  Fill that side up with carb spray and stand on end.  Let soak.  Drain.  Take a awl pick and see if you can spin the rotor.  If it breaks free.  Slowly spin it.  Spray more carb spray.  Drain.  Hook up and see if it spools up when you turn the ignition switch on.
