Author Topic: Sachse ZDG3 Electronic Ignition. It is alive!(Video)  (Read 9003 times)
Dobermann
« on: February 26, 2016, 01:40:04 AM »
Greetings everybody!
Here is a video of the bike running with Sachse ZDG3 electronic ignition. Once we figured out what we think is the best advance curve it came alive.
http://www.youtube.com/watch?v=79oh_Uy6d3U
Offline Old Jock
Re: Sachse ZDG3 Electronic Ignition. It is alive!(Video)
« Reply #1 on: February 26, 2016, 05:49:22 AM »
Nice
Here was mine on an early start up
https://youtu.be/-G5zCu5UkEA
I too had a bit of a problem finding the right curve, but I got it sorted with advice from the folks on here. Mine runs a PuReg combined Reg/Rec and ignition triggers, the actual box lives under the seat.
Offline not-fishing
« Reply #2 on: February 26, 2016, 05:58:18 AM »
Wow, $400 for my little V50, I'll probably just stick with points.      Ho braccia corte   :laugh:
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
« Reply #3 on: February 26, 2016, 08:32:00 AM »
A Dyna S ignition is much less expensive.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=37_157&products_id=1598
Dobermann
« Reply #4 on: February 26, 2016, 10:38:34 AM »
Nice
Old Jock I would like to thank you again. Maybe you remember or not but you helped me alot with your m-unit wiring diagrams and knowledge. Thank you!
« Last Edit: February 26, 2016, 10:40:48 AM by Dobermann »
Offline Old Jock
« Reply #5 on: February 26, 2016, 12:49:02 PM »
Helped a few people over the years with the M-Unit.
No need to thank me a pleasure to help another Guzzi enthusiast out, especially if it contributed in some small way to the stunning end result.
I'm glad
1) The info was useful
2) That you could decipher it in the first place  :wink:
Your machine look absolutely gorgeous, tastefully done and also a first rate build.............. ......all I can say is Wow!!!!! :bow:
Offline v65tt
    • Streffords
« Reply #6 on: February 26, 2016, 02:37:38 PM »
worth every penny, thats what i have on the mighty V7TT
Iain
1986 V65TT
2016 SWM SILVER VASE 440
1974 HONDA XL250 MOTOSPORT
http://www.streffords.net
« Reply #7 on: February 27, 2016, 09:30:47 AM »
GREAT looking Guzzi :bow: :bow:
Cheers
Jim
Offline earlgrey-erfurt
    • handmade vintage watches
« Reply #8 on: February 27, 2016, 05:34:40 PM »
Be careful with holes in the ignition cap/cover. it needs half a year to figure out why my guz running strange on warm weather... :violent1:.
Solution some bright sunbeam find its way reflected from the chromeexhaust through the extra cooling holes.... and irritated the beam sensor
cheers
and the ZGD is worth every penny
GUZZI MEETS VINTAGEVDB_________ __________________
Dobermann
« Reply #9 on: February 28, 2016, 03:43:29 PM »
Thanks for the advice. Nice find. :)  I was going to get a drilled cover...
But now I better stick with my current cover. It does not have halls. I've putted two cooling flanges.
« Last Edit: February 29, 2016, 02:42:51 AM by Dobermann »
Offline peake271
« Reply #10 on: March 04, 2016, 12:39:30 AM »
What number curve did you settle for?
Offline Old Jock
« Reply #11 on: March 04, 2016, 03:46:28 AM »
On my LM 1000 I'm running curve 4 if it helps
Offline v65tt
    • Streffords
« Reply #12 on: March 04, 2016, 09:21:41 AM »
my v7tt likes curve 5 for best overall drive and curve 7 or 8 for max top end power
Iain
1986 V65TT
Dobermann
« Reply #13 on: March 18, 2016, 10:43:39 AM »
Also curve 5 for my LM2.
« Last Edit: March 18, 2016, 10:45:57 AM by Dobermann »
« Reply #14 on: March 18, 2016, 01:07:59 PM »
So John, from the pictures it appears to have a different optical sensor for each cylinder, since it is operating at crankshaft speed presumably it sparks each rotation.  (lost spark)
Or does it still use the distributor?
How does it take care of spark advance?
Is it normally set for the beam to break at the advanced position then delayed with a microprocessor?
Does it fire when the beam is broken or when it's made?
What are the curves you speak of?
Curious minds need to know.
« Last Edit: March 18, 2016, 01:13:33 PM by Kiwi_Roy »
Offline fossil
« Reply #15 on: March 18, 2016, 02:45:28 PM »
Stefan, great looking bike. The indicators look familiar. I have them on my old Honda ST 70 DAX.
Greetings from Germany!
Thorsten
Dobermann
« Reply #16 on: March 19, 2016, 04:49:13 AM »
Thank you Thorsten. Yes they are Honda indicators with a little polish.
Offline Old Jock
« Reply #17 on: March 19, 2016, 07:24:10 AM »
Heh Roy, howya?
It has 2 sensors one for each cylinder and yes it fires the spark once every revolution, so wasted spark.
However just to elaborate (or bore) the collective, there is a lot of talk about wasted spark being a VERY bad thing on the Guzzi engine configuration and yes it can be less than desirable. This is when in a wasted spark setup you have one sensor on a 1/2 engine speed rotor, this means the wasted spark fires when the other cylinder requires a spark for ignition. This can be bad as the RH cylinder will be receiving the spark on the induction stroke which can cause ignition and subsequent blowback through the carb (via the open inlet valve). Usually no more than a burp during riding but at idle RPMs can lead to you "cooking your goose"
With the double trigger on an engine speed rotor (as the Sacshe has) the wasted spark occurs close to the top of the exhaust stroke vastly reducing the chance of any form of blowback.
It no longer requires the distributor and mine is removed a cover plate covers the gap where the distributor once sat.
Spark advance is calculated via electronics in a box, the triggers are set to zero advance by moving the rotor to get the correct timing, the advance is then taken care of by the magic box. I think that answers 2 of the questions no?
On the electronics box is a rotary switch for advance curve selection.
The triggers are activated on beam disrupt i.e. when the rotor disrupts the beam, so on advance edge. When setting it up initially you move the rotor and an LED on the board (you can see them on the videos on posts 1 & 2) lights.
Curves are below
For Twin plugged bikes
Dobermann
« Reply #18 on: March 19, 2016, 07:39:25 AM »
Great explanation, John.
Also recently Sachse started producing a distributor mounted ignition pick-up.
