Author Topic: Spoked wheel disassembly soaking solution  (Read 3793 times)
Offline BSABEN
« on: February 29, 2016, 06:17:42 AM »
I would like input on an economical solution to soak my wheels in to loosen the spokes. My idea is to submerge the whole wheel for two weeks while I'm on vacation.
Any thoughts?
Re: Spoked wheel disassembly soaking solution
« Reply #1 on: February 29, 2016, 07:17:52 AM »
 What type and brand of spoked wheel ?
Offline BSABEN
« Reply #2 on: February 29, 2016, 10:53:21 AM »
1972 El Dorado
Offline Mike Tashjian
« Reply #3 on: February 29, 2016, 11:49:57 AM »
If your not trying to reuse them I use bolt cutters.  Otherwise any penetrating fluid of your choice can just be sprayed on periodically instead of soaking the whole wheel.  I doubt you would use a whole can.  I think ATF mixed with something(Acetone?) is suppose to be a real good one of the home brew style.   Mike
Offline old as dirt 2
« Reply #4 on: February 29, 2016, 12:08:56 PM »
the very best penetrant is Aerokoil ,  http://www.kanolabs.com
2013 Norge
2008 MP3 500
bunch of other stuff that is long gone.
« Reply #5 on: February 29, 2016, 12:19:01 PM »
An Eldorado has nice stainless steel spokes, it would be a shame to cut them.
« Reply #6 on: February 29, 2016, 05:21:43 PM »
 :1:
Offline jbell
  • Some progress
« Reply #7 on: February 29, 2016, 06:12:35 PM »
To loosen stuck nipples, frequent spray of penetrating fluid.  If the spokes are stuck in the hub, careful application of heat to the hub (use a non-contact thermometer to prevent disaster), drill a spoke sized hole a couple of inches deep into an aluminum bar and use that to tap out the spoke.
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
Offline jetmechmarty
« Reply #8 on: February 29, 2016, 06:23:04 PM »
Steel rim?
This stuff will destroy the corrosion.  If the rim is chrome, it won't hurt it.  It's the answer.  Sometimes Home Depot has it.
Marty (in Mississippi)
No Guzzi right now
« Reply #9 on: February 29, 2016, 07:11:22 PM »
Must be okay.  The hand in the picture is in the solution. :tongue:
« Reply #11 on: February 29, 2016, 09:34:57 PM »
Steel rim?
Alloy rim. Rust isn't the issue.
Offline JoeW
    • The Guzzi Doctor
« Reply #12 on: February 29, 2016, 11:46:09 PM »
White vinegar. Works wonders.
Joe Walano
« Reply #13 on: March 01, 2016, 12:16:12 PM »
I like the ATF acetone mix for lots of stuff including the OP's.
I mix it up in El Pato cans and use a rubber cat-food can cover to keep the acetone from evaporating.
Dabble it on with little grease brushes or the like.
Other favored uses for the mix:
Lug nuts
Suspension components
Firearms
Pocket knives
Gate hinges
Great penetrant.
Todd.
Offline jabberwocky
« Reply #14 on: March 01, 2016, 04:29:37 PM »
Are you just assuming they are seized up? I just disassembled/reassembled my rear wheel, which was pretty crusty, but none of the spokes or nipples  stuck. I just sprayed wd40 on everything just minutes before proceeding to take it all apart.
Offline BSABEN
« Reply #15 on: March 01, 2016, 04:41:49 PM »
I haven't tried loosening them but since I'm in no hurry I figure it's best to soak them. I had seen the acetone/ATF recommendation but I posted to see if anyone had actually used this mixture for this task. Think I'll give it a try
« Reply #16 on: March 01, 2016, 04:45:30 PM »
That's very often my pre-ATF thinking: "Why risk it?"
Todd.
