Author Topic: Short somewhere?  (Read 2332 times)
Offline bassa99
Short somewhere?
« on: March 01, 2016, 05:21:10 PM »
Working on starting Walter and when battery is installed both rear turn signals flash with ignition off. Prior to engine removal this was not the case so I may have pinched wire possibly. It seems strange both flash. Also horn works with ignition off is this normal? I don't want to get in to far without some advice from this  group. Bike is 74 Eldorado police model.
Allan
1999 Bassa
2001 Confederate Hellcat
1973 Norton Commando restoration project
Offline Markcarovilli
Re: Short somewhere?
« Reply #1 on: March 01, 2016, 06:56:45 PM »
Yeah there is a switch for those flashers and you have a wire making contact somewhere.  The horn will work with ignition off so that is OK.
MARK
« Reply #2 on: March 01, 2016, 07:00:20 PM »
 Do the flashers on loop frames switch through ground or hot ? Seems odd that only the rear flashers are blinking .
« Reply #3 on: March 01, 2016, 07:05:47 PM »
 If a short is when a circuit is being made complete where it is not supposed to,  What is a long?
« Reply #4 on: March 01, 2016, 07:17:48 PM »
 Cattle drivers term , as in "Git a long little dogies" .
Offline bassa99
« Reply #5 on: March 01, 2016, 07:45:09 PM »
I have spent some time looking for short in system no obvious sign. I did remove rear lights at fender to eliminate ground and rear lights stopped flashing bot green indicators on dash still flash.
I have moved switches in all directions with no findings of change. It is good to know horn can function with ignition off thanks. That helps to stop some of my head scratching.
1999 Bassa
