Author Topic: Shift return spring. Eldorado 850.  (Read 3489 times)
« on: March 01, 2016, 08:14:04 PM »
Anyone replace one?  So far no luck with checking Greg's "This Old Tractor".  I've looked at some manuals that I have and it's kind of sketchy as to where and what to do do.  One instruction was "Replace if needed."  :grin:   :shocked:  I'm looking at rotating the engine and trans up in the frame and pulling the trans back plate.  Not sure if that would do it for access to the spring.  Any suggestions.  Currently the trans is stuck in 1st and/or 2nd w/neutral.
« Last Edit: March 01, 2016, 08:15:17 PM by Tom »
Re: Shift return spring. Eldorado 850.
« Reply #1 on: March 01, 2016, 08:45:10 PM »
If you have the engine rotated forward with the trans. pointed upwards, 10 minutes more will have the transmission out and on the bench. I'd rather do it on the bench than in the frame.
Offline JoeW
    • The Guzzi Doctor
« Reply #2 on: March 01, 2016, 10:30:55 PM »
Like Charlie says, remove the trans from the bike and do it on the bench. Remove the rear wheel, swing arm, battery tray and tool boxes. Make sure you remove the rear brake light switch too, it can get crushed when getting the trans out of the frame. The bike will sit on the center stand and front wheel, I find it a little easier to get the trans out if you put a block of wood and a jack under the rear of the oil pan and raise it up a couple inches. It's a good time to inspect the U joint too.
Joe Walano
Offline Texas Turnip
« Reply #3 on: March 02, 2016, 08:05:19 AM »
The shifter spring on the Ambo was located outside the tranny and as far as I know it never broke. The spring used to cost 75 cents, but could ruin a 5 speed if it wasn't replaced when it broke
Good luck,
Tex
« Reply #4 on: March 02, 2016, 08:27:08 AM »
Good luck,
Tex
Yep. Even if it does break (after 45 years) it's a lot easier to replace.
« Reply #5 on: March 02, 2016, 09:10:30 AM »
As mentioned above, it's an easy job once you have the transmission on the bench. I wouldn't consider doing it any other way. BTW, the spring can be installed two ways. Only one is right.  :smiley:
Offline JoeW
    • The Guzzi Doctor
« Reply #6 on: March 02, 2016, 12:31:35 PM »
Here's a short video showing the correct installation of the spring on the shaft...
https://youtu.be/rT6VAm0jJiY
Joe Walano
Offline mtiberio
    • TiberioRacing
« Reply #7 on: March 02, 2016, 01:33:01 PM »
do yourself a favor and buy/make a tool to remove the output shaft nut (27mm open ended socket with a handle welded on the outside). do not attempt to do the job by pulling the rear cover and all the shafts with it. a fools errand.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
« Reply #8 on: March 03, 2016, 01:00:21 PM »
Thanks for the help so far.  Forgot to mention that it's on my hack.
