Author Topic: V9 parts lists are up.  (Read 2126 times)
« on: March 03, 2016, 11:48:50 AM »
Conventional Hemi head, single valve springs, not much of a dome on the Pistons so it'll be interesting to know how they got the CR up to anything useable.
Arse end gets a new driveshaft with twin hookes couplings, one at either end. Bevelbox, as with the Calis, is no longer listed as an item for which parts are available so you can't tell if it's been revamped or not.
Re: V9 parts lists are up.
« Reply #1 on: March 03, 2016, 12:56:08 PM »
So, when your bevel box seals start leaking, you buy a whole new box ?
« Reply #2 on: March 03, 2016, 02:15:43 PM »
That's the plan. Same as Cali 14. Needless to say it's bullshit, it's just an assembly so it can be taken apart and put back together. Only issue will be if there are some *Special* bits inside but as with the CARC boxes you can work around that.
« Reply #3 on: March 03, 2016, 02:22:55 PM »
Sorry, I tell a lie. There is an exploded diagram of the bevelbox in the 'Bobber' parts list, it is just marked as a unit in the 'Roamer'.
« Reply #4 on: March 03, 2016, 02:48:33 PM »
Good deal!   :thumb:
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #5 on: March 03, 2016, 03:47:24 PM »
The pictures are very light in the parts list, worse then before. Workshopmanual is 3/4 with v7 racer pictures and text, maybe they update that later. Or we may think that are the unchanged parts?
Pete, reardrive all parts are there but not the gears. So leaking can be solved.
The parts list are Eu/UK, but we do get a Fuel vapour recover system now too. And there is a secondary air system, pure mechanical, just a valve. it's mounted in the V centre so invisible from outside.
Paul
Daytona 1225, Stelvio 1151
« Reply #6 on: March 03, 2016, 04:42:24 PM »
Good to hear.
Workable head - single intake manipulator, I like it.
I wonder if I'll be able to talk myself outa my little Harley for one. That'll be tough.
Todd.
