Author Topic: Repacking Bub Mufflers  (Read 5895 times)
Offline Trinorman
« on: March 03, 2016, 07:28:24 PM »
I just picked up some Bubs for my V65SP and want to repack them.  Has anyone here repacked these particular Bubs?   From various searches, it looks like I have to drill out the rivet.  Then remove the baffle.  Has anyone removed one like this?  There is no way to really grip it to pull it out.  Can it be knocked out from the narrow end?  Maybe get some sort of hook into the baffle and yank it out?  Presuming I get it out, do I just need a sheet metal screw to replace the rivet?
Any input much appreciated.
Chris
1984 V65SP
Offline 265coupe
Re: Repacking Bub Mufflers
« Reply #1 on: March 03, 2016, 09:08:08 PM »
Wow. That SP looks new. Got any more photos?
Offline Guido Valvole
« Reply #2 on: March 03, 2016, 10:36:48 PM »
If they're like the Bub "Conti Replicas" I had on a Ducati Darmah 30 years ago, there is no packing in there. Glass-packs without the glass. Thinly-disguised open megaphones. 6000 rpm through the Alameda Tube, mmmmmm the sound of a big-block Can-Am car. And just as loud.
cr
V50 II
V50 Monza
Le Mans 1000 (IV)
Martinez, CA
Offline Trinorman
« Reply #3 on: March 03, 2016, 10:55:55 PM »
Definitely packing in there as it is visible, but blowing out.  Needs new packing, but want to know if I'm on the right track to get to it.
1984 V65SP
Offline BMCMOTO
« Reply #4 on: March 04, 2016, 06:28:42 AM »
Yes drill the rivet, mine just slipped out.  I packed with Moose Racing repack kit held with safety wire.  Mine were an actual muffler, not straight through.  Toned them down and mellowed the sound.  My understanding is that Bub used several different inner systems over the years so maybe not all are the same inners.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline chuck peterson
« Reply #5 on: March 04, 2016, 07:02:48 AM »
At your local Ace hardware, look for a variable thickness rivet to replace the one you drill out...
I used white bros muffler packing, held in place with hi temp tape...try doubling up
Used an axe handle to come in from the front and pop out the insert...
Made a beautiful sound when re packed but lasted maybe 10k before it got blown out
Best sounding muffler of an 80's vintage
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Cool Runnings
« Reply #6 on: March 04, 2016, 08:10:07 AM »
I replaced some Bub's once, drill out the rivets, pull out the guts and repack with steel wool.
Offline Tobit
« Reply #7 on: March 04, 2016, 08:46:21 AM »
+1 on drill the rivet, pull the baffle, wrap with Moose or other brand of repacking material and safety wire then re-insert.  Use a rivet to secure.  When I had Bubs, when the packing blew out there was a lot of crackle and other obnoxious farting on deceleration.  Repack and they were boomalicious again.
Now I have a set of Emgo Dunstall replicas and the same applies as far as packing.  Except they have three nuts to remove and pull the tube.
Tobit
Roman, '86 LM IV
Offline Trinorman
« Reply #8 on: March 04, 2016, 12:23:30 PM »
Thanks everyone for all the tips.  I don't have a riveter so will have to try a sheet metal screw or something.  I've got the packing material as I also have an Emgo Dunstall replica on my Honda GB500 which needs repacking occasionally.
Chris
1984 V65SP
Offline ritratto
« Reply #9 on: March 04, 2016, 12:56:23 PM »
Pop rivet guns are cheap. Screws will back out from vibration, more likely than not.
1978 G5
1998 Centauro ( oppsidaisy!)
2003 V11 LeMans
« Reply #10 on: March 04, 2016, 12:58:07 PM »
Chris
Steel wool from the hardware store works just as good.  :boozing:
Offline Trinorman
« Reply #11 on: March 05, 2016, 11:40:30 PM »
Bubs successfully repacked today and buttoned back up with a new rivet.  Thanks again everyone.
Chris
1984 V65SP
Offline ritratto
« Reply #12 on: March 06, 2016, 07:52:37 AM »
So, what packing did you end up using? I have a pair that need it too.
1978 G5
2003 V11 LeMans
Offline wrbix
« Reply #13 on: March 06, 2016, 09:29:44 AM »
Sounds like a recipe for rust
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
Offline Trinorman
« Reply #14 on: March 06, 2016, 02:46:39 PM »
I don't know the brand name.  Several years ago I got a bunch of it from a company called Rewarder Headers locally who make custom headers and exhaust systems.  They have it in bulk rolls for their business.  The owner was kind enough to just give me some for a bike that I was working on at the time.
Chris
1984 V65SP
Offline ritratto
« Reply #15 on: March 06, 2016, 10:38:48 PM »
Ok, but was it fiberglass or stainless wool? Thanks.
1978 G5
2003 V11 LeMans
Offline Trinorman
« Reply #16 on: March 06, 2016, 10:51:41 PM »
Fiberglass.
1984 V65SP
« Reply #17 on: March 06, 2016, 10:53:03 PM »
You can get stainless steel wool, which is the right thing to use for something like this if you're going with steel wool.
« Last Edit: March 06, 2016, 10:53:27 PM by Triple Jim »
