Author Topic: New Type Reusable B750 Rocker Gaskets  (Read 2630 times)
« on: March 07, 2016, 02:13:49 PM »
Just a quick question. With the older style gaskets I have always used a light smear of grease on them so that they are able (sometimes) to be used again. With the new black reusable ones is this necessary or do they just separate off without needing to be greased?
« Last Edit: March 07, 2016, 02:14:22 PM by Muzz »
Re: New Type Reusable B750 Rocker Gaskets
« Reply #1 on: March 08, 2016, 01:42:11 AM »
Unashamed bump.
Someone must know. :undecided:
« Reply #2 on: March 08, 2016, 01:46:41 AM »
Sorry, didn't see this. I just clean off the mating surfaces carefully and stick 'em on dry.
« Reply #3 on: March 08, 2016, 02:29:51 AM »
Excellent. Thanks Pete.
Offline Vagrant
« Reply #4 on: March 08, 2016, 05:34:20 PM »
I keep a can of Pam no stick for frying pans in the garage. best tire lube I've found and I spray both sides of gaskets and reuse them a dozen times. before you say I will crash and burn I got the idea from the no-mar tire changer outfit. they sell a small bottle of vegetable oil for many $$$. most likely repackaged Crisco.
