Author Topic: Dash light bulb retro fits  (Read 5459 times)
Offline giusto
  • Giusto il canne del Como
    • photobucket
« on: March 12, 2016, 09:28:44 PM »
Hello,
I know I've seen comment regarding replacement of OEM Guzzi dash light bulbs here in the past. I'm sure options vart with all the higher tech bulbs out lately to retro fit LCD or LED or?
I was out for a magnificent ride today in Northwestern Lower Michigan on my 84 V65C and really noticed on this sunny day how poorly lit the dash is. Please let me know what has worked for you all.
Thanks for the help
2020 V 85 TT Travel
76 V1000 Convert Mr. Slate
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
Offline Groover
    • Scooteropolis
Re: Dash light bulb retro fits
« Reply #1 on: March 13, 2016, 12:09:20 AM »
I found the dash lights pretty useless during the day time on my 81 G5, which I believe has a similar dash as yours. I decided to get LED bulbs for the dash turn signal indicators only however, and that's my recommendation. If you upgrade the others to LED it might just be "
too much light shining in your eyes at night. Some upgrade them all, so that's a personal preference.
Things to know. Best to use the same color LED as the lense its to shine through (green/green)
Also, if upgrading the whole dash, leave the generator bulb factory as the LED might cause the charge circuit the not charge properly. However, someone here just did put an LED in the position and the charging still works, so at least know that if you do change it to LED be sure to verify if the bike charges or not.
The upgrade on the dash turn signals was a huge improvement. It's like day and night ;-)
I can post the part number later if you can't find it.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline Zoom Zoom
« Reply #2 on: March 13, 2016, 05:15:46 AM »
Groover covered it very well.
Here is a good source for LED bulbs. I have been dealing with them for some time.
https://www.superbrightleds.com/
John Henry
Offline giusto
    • photobucket
« Reply #3 on: March 13, 2016, 06:24:25 AM »
Thanks John, thanks Groover!
Much appreciated.
The nutral light is also almost non exsistant and since my son will be riding this bike I think I'll go with changing it and the directionals.
2020 V 85 TT Travel
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
Offline jkguzzi
    • JKnorth
« Reply #4 on: March 13, 2016, 07:59:16 AM »
When I had the Convert I changed the dash lights to LED and it made a BIG difference in the daylight but were still not annoying in the dark although I rarely rode at night. Still left the standard charging bulb.
Offline TodkaVonic
« Reply #5 on: March 13, 2016, 08:03:21 AM »
It's an easy swap that makes a significant difference. Also they last for something like 10 years and take a teeny tiny bit of energy. Win win win, win.  I bought mine from superbrightleds as well.
2021 BMW R18 First Edition
2006 Ducati Sport Classic Paul Smart
1970 Moto Guzzi Ambassador
Offline Groover
    • Scooteropolis
« Reply #6 on: March 13, 2016, 08:27:00 AM »
Superbrightleds website is also where I bought mine. Changing the neutral is a good idea, I might do that on mine too.
The part number for the green bulbs for that socket type is: "74-GHP Green"
https://www.superbrightleds.com/moreinfo/miniature-wedge-base/74-led-bulb-1-smd-led-miniature-wedge-retrofit-car/227/
Final note: they are positive/negative sensitive. Meaning, if it doesn't light up, flip the bulb in the socket and it will work.
« Last Edit: March 13, 2016, 08:39:52 AM by Groover »
1980 Vespa SI Moped
Offline TodkaVonic
Offline not-fishing
« Reply #8 on: March 13, 2016, 09:10:30 AM »
For help to figure out which type of bulb you have these video's are the best.
www.bulbtown.com
https://youtu.be/eciBoWpy0pY
And all you low flying Guzzi Owners should know they also sell landing lights.
Mark
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
Offline giusto
    • photobucket
« Reply #9 on: March 13, 2016, 09:22:24 AM »
Thanks again
You guys are awesome... An answer, a part number and a source!
One stop shopping!  :bow:
2020 V 85 TT Travel
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
