Author Topic: V7 Stone Noisy cylinder  (Read 2973 times)
Offline v65tt
    • Streffords
« on: March 15, 2016, 12:47:25 PM »
Been looking into my v7 stone engines odd noises, very mechanical and knocky below 2500 rpm ( like piston slap) but soon as she clears 2500 she's lovely and smooth till the rev limiter.
stripped my new engine to discover that the left hand piston is the wrong way round from the factory...!
the arrow is pointing to the rear on the left hand cylinder and  the arrow points to the front on the right hand cylinder
Cannot find any movement or damage anywhere, even the carbon pads are like new, no movement in bottom end either.
Are low rpm nocks normal for the v7 single point engine.
Have 2 v7 II engines here and i have never seen so much carbon build up on heads and pistons in my life!
my old v65tt engine was just lightly sooty after 25k miles!
Iain
1986 V65TT
2016 SWM SILVER VASE 440
1974 HONDA XL250 MOTOSPORT
http://www.streffords.net
Re: V7 Stone Noisy cylinder
« Reply #1 on: March 15, 2016, 01:34:38 PM »
Hmmm... the left cylinder on my 2014 is a little noisier than the right.
Offline normzone
« Reply #2 on: March 15, 2016, 02:01:07 PM »
Alright...I'll play the fool here.
Is it possible it's a universal piston designed to go in both sides, with the arrow aligned differently for differing sides ?
I know, doesn't sound likely, but...
« Reply #3 on: March 15, 2016, 04:00:03 PM »
No.
Offline DaSwami
« Reply #4 on: March 15, 2016, 05:07:51 PM »
Wait what?  Details please.
« Reply #5 on: March 15, 2016, 05:31:11 PM »
It's been your winter hasn't it? Lousy signal from ETS. They always run black in winter.
Offline DaSwami
« Reply #6 on: March 15, 2016, 06:01:20 PM »
What is ETS??  Google is no help
« Reply #7 on: March 15, 2016, 06:47:00 PM »
Engine temp sensor.
Offline DaSwami
« Reply #8 on: March 15, 2016, 07:01:41 PM »
Engine temp sensor.
Thanks...makes sense.  It seems the oil on my CB1100 looks very dark after just a few runs in 30 degree temps, I bet on an oil cooled motor really cold temps bugger the works.  So would it be true it would all burn off in the heat of summer??
BigDave in PA
« Reply #9 on: March 15, 2016, 09:27:26 PM »
I'm assuming that they are valve reliefs in the piston. The smaller one would definitely go to the front cause the intake is the larger valve. It doesn't look like there was any contact though.
« Reply #10 on: March 16, 2016, 03:03:22 AM »
 :shocked: :shocked: :shocked:
That Luigi!!! He needs a good  :whip2: and a good  :boxing: and a  :violent1: for good measure. Then I hope the  :thewife:  chimes in as well.
That is inexcusable.
Offline v65tt
    • Streffords
« Reply #11 on: March 16, 2016, 12:44:33 PM »
it ran fine with about 9000km on   ( bar engine i bought for project v7TT number 2)
Anyone else find there single throttle body V7's very knocking below about 2500 rpm?
Iain
1986 V65TT
