Author Topic: breva 750 dipstick length  (Read 1717 times)
Offline breva750
« on: March 28, 2016, 05:36:45 PM »
I would appreciate dimensions as I am fabricating a replacement....
Offline sign216
Re: breva 750 dipstick length
« Reply #1 on: March 28, 2016, 05:56:28 PM »
I remind you that in 2003 there was change by the factory, shortening the stick Full mark by 10mm.
This was to lower the oil level slightly, to reduce oil taken up by the air box.
Ironically , I don't know the overall length, just that it was shortened a little.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline breva750
« Reply #2 on: March 28, 2016, 06:03:01 PM »
mine is 2004 (thanks for that)
Offline Hugh Straub
« Reply #3 on: March 28, 2016, 08:01:36 PM »
My 2006 dip stick:
length from screw cap bottom to stick end - 131.1mm/5.16in
from bottom of stick to low level mark - 13.6mm/.53in
from bottom of stick to high level mark - 32.0mm/1.26 in
2003 service bulletin says don't fill with oil more than 10-11mm below high level mark (say 22mm from stick bottom)
Hope this helps.
Kind regards
Brgds
Hugh
"Often wrong, never in doubt"
