Author Topic: Why does my Stelvio keep giving an oil warning?  (Read 22489 times)
Offline Viker
« on: March 30, 2016, 05:54:02 AM »
The red light on the dash lights up, the LCD screen shows an oil can symbol. But the oil level is right where it should be, I�m pretty sure.
The first oil warning came as I arrived at work, descending a steep driveway after a 25 min ride. And the second warning was at the end of a 20 min ride, while ascending a driveway.
I checked the oil and sure enough, it was low. Oil seemed to have been leaking around the oil filler plug which holds the dipstick. It took almost a litre (just under a quart) to bring it up to level (two thirds up the narrow part of the dipstick). And I tightened the oil filler plug.
So far so good, right?
But the next day it happened again as I arrived at work. The oil warning came on while making a slow, tight, 120� left-hander in the carpark. Then off again after the bike levelled out. Then on, off, on, off. Then on again for the steep driveway.
So far not so good.
I checked the oil level again and it still seems fine.
Is there something else that might be triggering the oil warning on the dash?
Or am I measuring it wrong? I ride for 20 min, then level the bike on the centre stand, clean the dipstick and reinsert it as far as the first orange o-ring. Optimal level is 2/3 - 3/4 of the way up the thinner part of the dipstick, right?
What am I doing wrong? What am I missing?
Offline twhitaker
Re: Why does my Stelvio keep giving an oil warning?
« Reply #1 on: March 30, 2016, 06:08:21 AM »
It's an oil PRESSURE warning light. Once the oil pressure drops below a certain point (like idle) the light will come on. On the other hand your idle speed might be too low.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Online Gliderjohn
« Reply #2 on: March 30, 2016, 07:35:27 AM »
Are you running the recommended 10-60 oil? If not that may be the cause, especially as the weather gets warmer.
Back in central KS
Offline sbaker
  • Piaggio Stock Holder
« Reply #3 on: March 30, 2016, 07:38:05 AM »
Hello;
Mine does this same, it has since new, Oil is UP! .. 10-60 .. It comes on when coming off high rev. If I blip the throttle, it goes away and doesn't come back..
Sam
Dallas, TX
AGATT
Current
Norge Wing: White Squadron
Ducati 900ss
Previous
1975 Convert + Sidecar - Fun
2004 California EV Touring
Offline toma nova
« Reply #4 on: March 30, 2016, 07:42:26 AM »
Similar issue here.
Mine comes on every time I start the bike, no matter hot or cold or how long it has been sitting. Warning light only stays on for 2-3 seconds then off until the next start up.  Started before the last oil change, oil level is perfect at halfway up the dipstick.  Mobil1 20W50.
I'm thinking it's a loose oil pressure sensor connector. There's a post here and on GT about the stock pin connector and how to change it to a more robust spade connector, possibly with an updated sensor.
Can someone point me to the location of the sensor so I can check the connection?
Thanks,
2014 Stelvio NTX
2008 1200 Sport - sold
« Reply #5 on: March 30, 2016, 08:37:00 AM »
I would track it down ASAP though. You may have a damaged pump and be running low pressure all of the time. Or it may just be a whacked out switch.
What error code do you get on the dash?
« Reply #6 on: March 30, 2016, 01:24:47 PM »
I'd proceed from the assumption that the light is right until proven otherwise.  I'd get a pressure gauge on it and get the what's-up.  Or like someone said in another topic -- you can speculate for weeks . .. [while perhaps it proves it's right . . .  .]  Oil pressure isn't like the rev limiter.  You really do need to know.
Offline ITSec
« Reply #7 on: March 30, 2016, 03:08:34 PM »
Back when the 10w60 was introduced in Guzzis, a lot of people reported oil sensor misreads. A lot of them were running oil other than 10w60. I don't want to has out (again) the relative merits of oils, but I would suggest you try 10w60 in the flavor of your choice at the next oil change, and see whether this problem still occurs.
A sensor problem is sometimes characterized by occasional low oil pressure readings, but more often by red triangle and dashboard errors, which happen because the sensor either reads pressure when there is none (key on, but motor not running) or inaccurate readings while running (such as sudden and erratic changes in reported pressure, usually at lower rpm).  Red triangle on start, without showing an oil can symbol, is generally a sign of the sensor being suspect.
As for the location of the sensor and connection, that can be problematic (I was the one who offered the alternative connectors). The sensor is located inboard of the left cylinder, more or less underneath the alternator. If your bike uses the original design sensor with the nail-head connector, changing the connector has resolved many of these problems (no one has reported them again after changing the terminal connector on the wire). If you obtain one of the new generation sensors, then you have to change to a spade (female) in any case, unless your bike is recent build date and has it already.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline Viker
« Reply #8 on: March 30, 2016, 03:26:44 PM »
Thanks everyone.
10w60? Yep.
Error code? None that I've seen, just the red LED and the oil can icon. I'll stop and check the LCD for codes if/when it happens again.
My bike is a 2014. Does anyone know when the sensor design was changed?
Thanks, Viker
« Reply #9 on: March 30, 2016, 05:58:55 PM »
It should have the error code in memory if you look for it.
Offline leafman60
« Reply #10 on: March 30, 2016, 08:08:15 PM »
If I recall correctly, there is a question about dipstick accuracy. If you pour in anything near the stated capacity of oil, in some cases, it may read high on the dipstick.
Mine stays just above the narrow part of the stick. Never had a warning come on.  Never had any blow by on sustained high speed running.
« Last Edit: March 30, 2016, 08:21:45 PM by leafman60 »
Offline Mark111
« Reply #11 on: March 30, 2016, 08:40:46 PM »
Could be just a dud oil pressure switch, not uncommon.
But to be safe you should get the oil pressure checked especially if it is an older engine and has had wear from the flat tappets which could have caused abnormal wear to the oil pump.
Even if you had to add a litre of oil there should have been enough in the engine so that the oil pressure light would not come on.
Offline toma nova
« Reply #12 on: March 30, 2016, 08:48:17 PM »
Mine's a 2014 so no flat tappet wear and theoretically the newest sensor design.  No error codes in the dash or in memory, just the red triangle and oil can with "SERVICE".  I'll take a look at the sensor to rule out the connector and look more closely at the oil level.
Thanks.
2014 Stelvio NTX
Offline Viker
« Reply #13 on: March 31, 2016, 06:25:20 AM »
The dashboard error code is DSB 08: oil pressure fault, not DSB 07: oil sensor fault.
The bike is 2014, purchased new in June 2015, 11,500 km on the odo.
Maybe I should add a couple hundred mm of oil each day until the warning stops appearing.
« Reply #14 on: March 31, 2016, 06:39:29 AM »
Or just replace the sensor which costs a few bucks and see if the problem goes away. If it doesn't? Delve deeper.
Offline kirb
« Reply #15 on: March 31, 2016, 07:23:02 AM »
...and there it is. The proper way to troubleshoot this problem (it does require taking off the red suspenders for a day)
« Reply #16 on: March 31, 2016, 09:37:24 AM »
It isn't that sensitive to oil level.
Start by installing a new sensor like Pete suggests.
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #17 on: March 31, 2016, 12:40:08 PM »
be prepared for the oilswitch hassle, they don't supply the same that it has anymore.
Paul
Daytona 1225, Stelvio 1151
Offline Viker
« Reply #18 on: May 01, 2016, 06:14:21 AM »
Thanks everyone for your thoughts and suggestions.
The cause was, as folks had said, a dodgy sensor.
The culprit was replaced under warranty.
Offline tris
« Reply #19 on: May 02, 2016, 12:46:50 PM »
For clarity what is the difference between a 07 error and 08 error and do they come from the same sensor?
Cheers
1993 TW125 "POS" - Resting
Offline Viker
« Reply #20 on: July 27, 2017, 06:10:11 AM »
Eventually, the oil pressure warning came back, so I had the sensor replaced again under warranty.
Then it immediately came back again, and they replaced it again.
And I'm still getting the warning. There's obviously some deeper cause.
Oil level is showing about 2/3 of the way up the notch wench the dipstick rests on the o-ring.
Which is about 1cm above the notch when the dipstick is fully seated.
What should I look at next?
« Reply #21 on: July 27, 2017, 08:28:39 AM »
You need to get a gauge hooked up and measure actual pressure.
« Reply #22 on: July 27, 2017, 08:49:30 AM »
From here it is almost certainly the gasket between the sump spacer and the block having blown out around the delivery gallery/ies. Don't ride the bike until it's fixed.
Offline Viker
« Reply #23 on: July 27, 2017, 05:07:59 PM »
Oh crap
I've already been riding it. What might that lead to?
« Last Edit: July 27, 2017, 06:07:11 PM by Viker »
« Reply #24 on: July 27, 2017, 06:34:21 PM »
You risk running the big ends and possibly the mains.
« Reply #25 on: July 27, 2017, 09:33:26 PM »
Picture of likely problem.
There is a new, thicker, gasket available.
Offline Viker
« Reply #26 on: July 27, 2017, 10:44:28 PM »
Pete, you are a legend. A national treasure in the Republic of Guzzi.
Is there any way I can check the suspect gasket without tearing the whole damn bike apart?
« Reply #27 on: July 27, 2017, 11:26:41 PM »
I've actually got a 1200 Sport on the bench right now with what I think is the same problem. I've swapped the sender to no avail so on Monday it's drop the sump and spacer. From memory you have to tie it vertical, (unless you have a centrestand.) because the sidestand mounting plate mounts onto the spacer. Then just drop the Sump and then the spacer, (Yes, you need to drain the oil unless you want to get very messy! :evil:).
Replace shitty old gasket with new thicker type and reassemble. Fill with oil, check light stays off when you start it. Go ride.
I can take a few pics as I do it if you like?
Edit. Yours is a Stelvio so you have a centrestand, easy! Bash plate has to come off first of course.
« Last Edit: July 27, 2017, 11:46:34 PM by pete roper »
Offline Viker
« Reply #28 on: July 28, 2017, 08:46:25 PM »
Is there a guide anywhere on how to do this?
Offline Viker
« Reply #29 on: July 28, 2017, 08:56:21 PM »
Pics would be fantastic. Thank you Pete.
I may have my Chicken Little hat on, but if the big ends and the mains were slightly fukced, what would the symptoms be? Noises? Could a shaved ape or a plucked sloth mistake those noises for cam chain issues, or exhaust gasket issues?
<deep calming breaths>
