Author Topic: Norge - Odometer Mileage Display  (Read 6851 times)
Offline Cool Runnings
« on: April 17, 2016, 04:07:04 PM »
The odometer moved to the lower part of the LED screen and now I get Trip 1 or Trip 2 miles where the odometer display was (big black area). Gas tank filled, can't move odometer back? What the heck happened?  :violent1:
Online PJPR01
Re: Norge - Odometer Mileage Display
« Reply #1 on: April 17, 2016, 05:52:53 PM »
Push the large button sideways like you do to get to trip 1 or 2 but hold it for about 5 seconds and It will change back, keep holding until it goes back to the original menu
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
« Reply #2 on: April 17, 2016, 09:35:10 PM »
Not working?
Thanks for the tip...
« Reply #3 on: April 18, 2016, 07:43:25 AM »
Just goes to trip 1, trip 2 or mode?
Offline JeffOlson
« Reply #4 on: April 18, 2016, 08:55:00 AM »
How far away is your dealer? If it is an easy ride, I would swing by the shop and have them look at it. Otherwise, I would call them while you are at your bike so they can try to walk you through it and confirm that there is indeed a problem (if there is a problem).
The Norge button is a bit odd to use. It requires an unusually firm push in and (while holding it in) slide to the side. You will feel an odd click when it works right. My Vespa mode button is far easier to use (just push in momentarily to cycle through and push and hold to reset), but it has far fewer display options than the Norge
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
« Reply #5 on: April 18, 2016, 11:40:29 AM »
Thanks, sounds like the best thing is to swing by the dealer (15 minute drive).  :boozing:
Offline Zoom Zoom
« Reply #6 on: April 18, 2016, 12:03:17 PM »
Sounds to me like a cracked spark plug boot. My Stelvio did something similar.
ZZ
« Reply #7 on: April 18, 2016, 01:19:46 PM »
ZZ
Interesting, I'm not really understanding but, valves were just adjusted not long ago by dealer?
Offline JeffOlson
« Reply #8 on: April 18, 2016, 01:23:26 PM »
The stock spark plug caps and wires are rubbish and should be replaced ASAP as a preventative measure. Otherwise, they are prone to a bad connection, creating all kinds of interesting electrical problems (e.g., arcing to ground, a cylinder not firing, etc.)
2018 Vespa GTS 300
2015 Vespa GTS 300
« Reply #9 on: April 18, 2016, 01:46:54 PM »
It was common on the early Stelvios for a spark plug boot to crack, and the arcing could cause enough RFI to make the dash display nutty things.
Yours doesn't really sound like that, but I might be worth a try to disconnect the ground on the battery for a couple of minutes to see if that straightens it out.
« Last Edit: April 18, 2016, 01:47:35 PM by OMG »
« Reply #10 on: April 18, 2016, 04:49:30 PM »
Good idea?
Had my 1,000 mile service done around 600 miles. I see the 'wrench' is displayed now. Can't access 'diagnostics', looks like that area is for dealers only. My question now is, if I do my own service, how do I reset the 'wrench'?
PETE!  :boozing:
« Last Edit: April 18, 2016, 05:02:23 PM by Cool Runnings »
beetle
« Reply #11 on: April 18, 2016, 06:20:45 PM »
Norge service code: 28315
Offline ITSec
« Reply #12 on: April 18, 2016, 08:07:30 PM »
A couple people have supplied the code, but haven't told you how to use it.
With the bike's ignition on but the engine NOT running, press AND HOLD the MODE switch until you see the display change to CHRONO instead of TRIP1 or TRIP2. Release the switch, then press it again WITHOUT HOLDING IT until the display shows MENU. Press the MODE switch IN and hold it until it presents a menu of selections at the bottom of the display. Use the MODE switch to scroll down until DIAGNOSTICS is highlighted. Press the MODE switch IN and hold it until the display changes - it will prompt you for the code (28315). Press the MODE switch right twice to change the first digit to 2, then press it in to move to the next digit. Repeat until you have entered all five digits; when you enter the final one, the ECU will accept it and will present a hidden menu. Scroll through this menu until you see the selection to reset the service indicator. With that highlighted, press the MODE switch IN and hold it until you are prompted to confirm your choice. Scroll until YES is highlighted, and press IN  and hold again to confirm that you want a reset. Once accepted, you will be returned to the selection menu. Scroll through each menu to EXIT, press IN and hold to select, and repeat as necessary to get out of this, and return to where you can select the standard display readings.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #13 on: April 18, 2016, 08:27:44 PM »
now you know more than your "dealer"
If you trust them..
Offline Waltr
    • Europa Macchina
« Reply #14 on: April 18, 2016, 10:20:25 PM »
The wrench will display at  programmed milage intervals. If it is not displayed at time of service there is no way to stop it by telling the service was performed.
Messed up but no way around it, I always tell people to expect it and is they don't want to fool with is just stop back  when they get a chance.
www.motoguzzipa.com
2012 Norge
« Reply #15 on: April 19, 2016, 12:13:52 AM »
I thought you could reset it any time. Shows how much I know! :evil:
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #16 on: April 19, 2016, 12:36:43 AM »
If you have heated grips, when activated the trip mileage will move down on the display to accommodate the heated grips symbol.
But it sounds to me that your dashboard has issues.
« Reply #17 on: April 19, 2016, 07:18:43 AM »
Brilliant, thanks.  :bow:
« Reply #18 on: April 19, 2016, 07:20:14 AM »
now you know more than your "dealer"If you trust them..
Not so sure of their knowledge regarding Guzzi's.
Offline Zoom Zoom
« Reply #19 on: April 21, 2016, 05:25:43 AM »
Just curious if you have had a chance to dig into this any more?
John Henry
« Reply #20 on: April 21, 2016, 05:09:35 PM »
Well, maybe I'm just an idiot. Is ODO suppose to read at the bottom of the display (small display) or in the middle surrounded by the black rectangle (large display)?
Offline ITSec
« Reply #21 on: April 21, 2016, 06:37:51 PM »
Well, on my Norge the full ODO has always been at the bottom, and has never appeared anywhere else. The TRIP displays move when the heated grips are activated, and return to their normal location when the grips are turned off. After 5 years I still occasionally discover something new about the dash display, so I accept that your description may be possible - but I've never seen it.  :gotpics:
ITSecurity
« Reply #22 on: April 22, 2016, 08:13:22 AM »
Ok, sounds like I shut off the heated grips and the TRIP moved?
