Author Topic: moto guzzi mag wheels tubeless conversion  (Read 3846 times)
Offline arveno
    • ddleathers.com
« on: April 20, 2016, 01:39:53 PM »
I have a set of mag wheels from a 1990 california III and i would like to use them tubeless.
I did use the search to find info on how to use them tubeless and found that this valve stem from Harper is what i need :
http://www.harpermoto.com/tubeless-valve-stem.html
Can I use these instead ? ( i do not see a big difference .)
http://www.ebay.com/itm/NEW-PAIR-Tubeless-Tire-Valve-Stem-Steel-for-Scooter-Motorcycle-ATV-Moped-Go-Kart-/221500810789?hash=item33927a2625:g:N0kAAOSwVFlUFmyn&vxp=mtr
How about the rubber one ?
http://www.ebay.com/itm/BIKEMASTER-Motorcycle-Wheel-Rubber-Tubeless-Valve-Stems-151563-4-Pack-/121275572114?hash=item1c3c965f92:g:bScAAOSwLVZV10hm&vxp=mtr
what else do i have to do ?
thanks
Marco
« Last Edit: April 20, 2016, 01:41:36 PM by arveno »
Re: moto guzzi mag wheels tubeless conversion
« Reply #1 on: April 20, 2016, 01:53:30 PM »
I used a tank valve (I think thats what they called it) got at the hardware store for about $5. it came with a tap so I threaded the hole and it screwed in with a little sealant.
Offline arveno
    • ddleathers.com
« Reply #2 on: April 20, 2016, 02:27:57 PM »
Offline Groover
    • Scooteropolis
« Reply #3 on: April 23, 2016, 07:29:56 AM »
I thought the Cal3 rims were of tubeless designation already? What are the markings on the rims?
Either way, I used the Drag Specialties type on my 81G5.
http://www.motorcycle-superstore.com/22509/i/drag-specialties-metal-valve-stem?WT.ac=SLIsearch
Drag Specialties: Part: VS-1218R
Hope that helps
« Last Edit: April 23, 2016, 07:32:23 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #4 on: April 23, 2016, 10:45:52 AM »
Yep, same kind of stem on mine too.  I did have to turn down the diameter of the part inside the wheel to fit the recess in my rims.  I only used the rubber part on the inside of the wheel.  Also applied some RTV around it when installed.  They have been on my bike now for about 50k miles with no issues.
Offline Groover
    • Scooteropolis
« Reply #5 on: April 23, 2016, 12:05:54 PM »
I also used the inner seal only and a little RTV. I'll probably turn the rims down next tire change as I didn't quite like how the rubber squished unevenly to follow the curved shape of the rim. It works though, on year two now and all is well. I did have to also cut the valve cap a few mm so it would tighten all the way. The valve stem itself could be a little longer for these conversions. NAPA has one that also works and the stem is longer on theirs. I have the part number somewhere.. I'll post next week if needed.
Edit: I used two nuts back to back to lock them which is why I had to cut down the cap a little. Otherwise, the cap would have fit fine.
« Last Edit: April 23, 2016, 12:13:02 PM by Groover »
1980 Vespa SI Moped
Online Perazzimx14
« Reply #6 on: April 23, 2016, 01:37:44 PM »
NAPA also has screw type valve stems for a couple of bucks each.
« Reply #7 on: April 23, 2016, 04:30:46 PM »
1990 Cal III mag wheels should tubeless from the factory.  IIRC.  '91 mag wheels are definitely tubeless but with Guzzi, you never know.  You won't know unless you take a look at the rim and the valve stem.  You'll definitely know when you pull the tire off.
