Author Topic: Eldorado tach  (Read 2346 times)
Offline MontGuzzi
Eldorado tach
« on: April 24, 2016, 10:55:16 AM »
Hi there, I am new here and just got my 73 Eldo back on the road. It had been sitting for 20 years and now has a big bore kit and fresh valve job. Running like a top! One mystery to be is the tach. When changing revs it can swing pretty wildly, giving more of a suggestion rather than indication of engine speed. Is this normal?
Offline lazlokovacs
Re: Eldorado tach
« Reply #1 on: April 24, 2016, 12:09:03 PM »
mine worked perfectly when I bought the bike, then started to swing all over the place, perhaps as you have stated, then started working in reverse at times...
I unplugged it and it hasnt bothered me since... but watching this thread with interest
Offline Rich A
Re: Eldorado tach
« Reply #2 on: April 24, 2016, 12:26:16 PM »
Check the points gap.
Rich A
Offline nick949
    • Nick Adams Writing
Re: Eldorado tach
« Reply #3 on: April 24, 2016, 12:39:48 PM »
You're lucky it works at all. Mine is erratic: either it doesn't work at all, or it is all over the map - a bit like the speedo!
Nick
Re: Eldorado tach
« Reply #4 on: April 24, 2016, 08:00:08 PM »
I have gone through two used ones, then I bought a reproduction Veglia tach from Spain, problem is its calibrated to indicate twice the rpm!!
The original tach has a cast weight sandwiched between plastic, the casting swells, splits the plastic and then the erratic readings begin. Eventually the tach shorts out and this will short the ignition.
I think Speedhut sells good modern replacements.
Jim
Re: Eldorado tach
« Reply #5 on: April 25, 2016, 03:24:53 AM »
Mine is not working but who needs a tack on an Eldorado anyway.
If I could find new chrome rims I might be tempted to open it up but it looks good at the moment.
