Yes, whoosh when I pull the gas cap.
Your vent circuit isn't working -- reversed tipover valve/deliberately plugged hose/kinked hose/evap canister removed/vent in tank plugged, etc. Sometimes it's just the way the tank was set obstructs the hose. Clear the vent line and the problem should go away.
Am I missing something here...Or maybe having a "Senior Moment"? I have an '03 Stone Touring which uses the same power train as the 03 EV and there is NO PETCOCK on the '03 or '04 California (hydros) models, which all have the pump inside the tank.
Great Suggestions! I really appreciate the help...though I have been riding most of my adult life I am by no means a mechanic. For those of you that are following up...problem solved bike is running perfect. The problem was caused by a Clogged Vent line. Thanks Again!
That is interesting. Since the pump should have enough power to suck a full vacuum, the vent shouldn't mean much.But, if you have the pump in the tank, that would also goof up the regulator reference. So......maybe....Need more coffee.
Not to be argumentative, Wayne, but why do you think the pump should be able to pull a vacuum? I've got vacuum pumps in my shop -- believe me -- they're a completely different class of animal than a fuel pump.Everything I've read and been told (I talked to the good folks at Carter Racing, who makes efi pumps) says the pump is very weak on the 'suck' side. That's one reason the filter is downstream of the pump why the external pumps are under the tank, and one reason why they eventually moved the pump to inside the tank. I've used the external pump to evacuate a marine fuel tank, and it was unable to suck a 2' column of gas. On the trike I starved a pump to death trying to suck gas the height of a jerry can.And think about it another way -- if the pump WAS capable of pulling a full vacuum AND the tank vent was plugged, you'd crumple the tank like a wad of tin foil with the pressure differential.So I'll respectfully disagree.
