Author Topic: SP 1000 fairing mount ?  (Read 2208 times)
Offline arveno
    • ddleathers.com
« on: April 24, 2016, 03:23:56 PM »
Hi all,
Does anyone have a picture or a print that shows how the fairing is mounted on a SP 1000 ?
I tried to search but did not find anything helpful.
thanks
Offline LeRoy
Re: SP 1000 fairing mount ?
« Reply #1 on: April 24, 2016, 06:22:48 PM »
Do you have an SP with an un-mounted fairing or are you lacking the brackets? And, do you need just the main fairing of the lower bits that surround the cylinder heads?
Let me know if the Parts Manual diagram(s) would help. EDIT 7:29 PM: I can send you a copy by email or a complete CD of all SP 1000 manuals and documentation. Send me a PM with your email address or your full name and mailing address.
If I was sufficiently motivated I could also go out to the garage, move a bunch of stuff around, and take a few pictures if you are looking for specific areas.
Or, let me know if a combination of the above works for you.
« Last Edit: April 24, 2016, 06:30:40 PM by LeRoy »
LeRoy (Bob Sharp)
Rochester, MI  U.S.A.
'83 1000SP (as of Oct. 15)
« Reply #2 on: April 24, 2016, 06:27:12 PM »
Sorry, I looked back through all my pictures of my old SP and didn't find what you need. Maybe the parts manual would be a clue?
« Reply #3 on: April 24, 2016, 07:58:34 PM »
#18 & #19 are the upper mounts, #11 is the lower mount. The bottom of 18 & 19 attach to the top triple, the upper plate of them bolts to the fairing body. #11 is just an "L" shaped piece that bolts to the front of the lower triple clamp, the fairing bolts to it from below.
« Last Edit: April 25, 2016, 08:44:13 AM by Antietam Classic Cycle »
Offline arveno
    • ddleathers.com
« Reply #4 on: April 25, 2016, 05:08:06 PM »
Thank you !! :thumb:
