Author Topic: History of the Small Block - Cycleworld article on the V9 engine  (Read 4891 times)
Offline steven c
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline SED
Re: History of the Small Block - Cycleworld article on the V9 engine
« Reply #1 on: April 27, 2016, 10:25:05 PM »
Looks like lots of room for performance mods!
"Compared to the Carcano engine, the V9 uses polidyne cam profiles (in the ‘60s they were not there yet) featuring moderate lift—for easier maintenance and longer valve train life—and almost zero overlap."
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
« Reply #2 on: April 28, 2016, 06:11:30 AM »
Interesting indeed. Aero engine head..
this is the first picture of the new small block head that I've seen.
Offline Dean Rose
    • Twin Valley Riders
« Reply #3 on: April 28, 2016, 06:59:01 AM »
Very interesting.  :laugh:
Dean
Magnolia '02 EV
Sophia '06 Breva 1100
Offline leafman60
« Reply #4 on: April 28, 2016, 07:25:43 AM »
Looks like they took the aero head and utilized the modern practice of minimizing the surface of the combustion chamber.
Also, the passages on the spark plug side look to be interconnected.
I just wish they could have squeezed a bit more HP out of it.
Online rocker59
« Reply #5 on: April 28, 2016, 10:12:29 AM »
"The Moto Guzzi V9 Roamer is the best lightweight Moto Guzzi ever."
Offline SmithSwede
  • I don't want a pickle
« Reply #6 on: April 28, 2016, 01:11:40 PM »
I'm scratching my head over the driveshaft.   I could be wrong, but it looks to me like they added another U-joint so that the drive shaft could run constantly crooked, and they made the drive shaft crooked in order to provide room for an over-sized rear tire.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline mtiberio
    • TiberioRacing
« Reply #7 on: April 28, 2016, 01:24:52 PM »
they make it sound like the aero heads were based on a v700 head casting... pix above deny that
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline mtiberio
    • TiberioRacing
« Reply #8 on: April 28, 2016, 01:30:53 PM »
yes... no diff than any spine frame or cali 1400, and it does away with the carrier bearing.
« Last Edit: April 28, 2016, 01:33:58 PM by mtiberio »
Offline JeffOlson
« Reply #9 on: May 04, 2016, 09:40:05 PM »
That's a good, informative article!  :thumb:
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
Online chuck peterson
« Reply #10 on: May 05, 2016, 03:57:05 AM »
Excellent coverage, but too bad they missed the tractor connection...
That's a joke, son...
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Rainman
« Reply #11 on: May 06, 2016, 09:27:50 PM »
It's a Hemi !!!  :boozing:
'12 Stelvio NTX,  '96 1100i+15M
'06 Breva 1100, '00 Quota
'75 Norton Interstate - WIP
'03 Titanium - WIP
'00 Jackal ...
lucydad
« Reply #12 on: May 06, 2016, 09:49:54 PM »
It is a Hemi?  I need to go check the mail.
Damn.  I wish we had a Houston dealer.
Sounds like the V9 is a major upgrade to the small block.
Rough Edge racing
« Reply #13 on: May 07, 2016, 05:35:33 AM »
  Yes a low valve angle hemi head....And it looks very much like a early  Harley EVO head.... Most 2 valve designs, including the Dodge hemi. now have moved away from the shallow hemi and have oval or figure 8 shaped combustion chambers for a faster fuel burn with high compression and low octane fuels..
   In the late 1950's the US car makers flirted with Herron heads...The Ford "Mel" engine used in Lincolns and the immortal Chevy 409 (348) had Herron heads.  They were attractive because of good mid range torque....
« Last Edit: May 07, 2016, 05:36:48 AM by Rough Edge racing »
