Author Topic: 1998 V11EV Exhaust System  (Read 1673 times)
Online n3303j
  • Ron Cichowski
« on: May 01, 2016, 08:27:34 PM »
Recently bought a '98 V11EV with horribly loud mufflers (they are un-baffled).
A member of this group sold me a beautiful pair of stock second hand ones for my bike.
On my bike the H pipe with the crossover tumor that blocked the oil drain was replaced with a plain H pipe.
This H pipe has a slight bend that points a bit upward at the tail end.
The stock mufflers mounted on this H pipe are still a bit low and too close to each other.
Seems to me that the correct H pipe exit end should point a bit higher up AND a bit out on each side to make the mufflers mount without any undue pressure to properly install the stern muffler mounting brackets.
QUESTIONS:
Does the original H pipe have the exit ends pointed upward and outward?
Is there a substitute H pipe without the tumor that blocks transmission drain that has the correct bends to properly install the stock mufflers?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline jmac851
Re: 1998 V11EV Exhaust System
« Reply #1 on: May 01, 2016, 09:07:04 PM »
The original goes upward and slightly outward.
1967 V700
1969 Ambassador
1984 Cal 2
1996 Cal 1100
1998 EV 1100
2006 Breva 1100
1994 BMW R1100RS
Online rodekyll
« Reply #2 on: May 02, 2016, 12:29:18 AM »
Lots of tiny differences between 'plain' H-pipes -- straight and a couple different bends as well as long and short tail pieces.  A shop might be able to give yout the bends you need.  If not, sometimes cutting the xover and using a piece of pipe as a splice will allow you the movement you need to make it fit.  Before you go cutting up a perfectly good H-pipe though, see if someone has what you need and will swap.
