Author Topic: 2016 V7II Clutch  (Read 4196 times)
Offline Bradkap
2016 V7II Clutch
« on: May 02, 2016, 12:08:39 PM »
I have found that the clutch is nice and comfortable when the bike is cold, but after it runs for a while the clutch gets much stiffer.  Any thoughts ?  Is this just the bike's personality ?
Your comments would be appreciated.
Brad
Offline swordds
  • (504)234-9011
Re: 2016 V7II Clutch
« Reply #1 on: May 02, 2016, 12:24:45 PM »
Just FYI, I have a V7II and have not noticed that problem so may not be personality.
2016 V7II Stone
2016 Suzuki TU250X (lost in the great flood of ought 16)
In the future I will strive to tolerate everything except intolerance and to hate nothing except hatred.
Offline thepittsburghguzzi
« Reply #2 on: May 02, 2016, 05:53:54 PM »
Could it be that as the engine heats up and expands, something is pinching the cable where it is routed from lever to trans? I know the cables on these are routed tight to begin with. Might want to check and see if something is getting pinched?
2012 V7 Classic - Scarlet
1979 KZ750 Twin - Copper
-Paul
« Reply #3 on: May 02, 2016, 06:15:44 PM »
Even grease the ends & lube the cable.
Offline Clancy
« Reply #4 on: May 02, 2016, 06:47:16 PM »
I was going to say this too.
Cheers
Craig
Offline DaSwami
« Reply #5 on: May 04, 2016, 10:55:30 AM »
When I bought the very last V7 II Stone (and last MG sold ever) at Empire Motorsports I relayed all the clutch cable online woes lots of members were experiencing.  Their answer was "poor dealer PDI and setup".
First 400 miles mine has been perfect so far....
Offline SeanF
« Reply #6 on: May 04, 2016, 11:04:37 AM »
Visually trace the cable routing, esp its proximity to the engine.
Offline sign216
« Reply #7 on: May 04, 2016, 04:32:51 PM »
Yes, this was a problem with earlier models.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline sib
« Reply #8 on: May 04, 2016, 04:58:41 PM »
But not a problem on the V7II, where the cable is routed differently and nowhere near the cylinder heads.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline SeanF
« Reply #9 on: May 04, 2016, 07:41:36 PM »
Is it routed near any hot parts?
Offline sib
« Reply #10 on: May 04, 2016, 08:30:34 PM »
No.  Well, I suppose it depends on what you mean by hot.  On my V7II, the cable goes more-or-less right between the cylinders and straight back to the relocated end retainer.  My cable hasn't needed any adjusting or fiddling in the 8000 mi I've ridden since the initial adjustment.
Offline sib
« Reply #11 on: May 05, 2016, 07:07:59 AM »
It seems possible that the clutch-actuating push rod, which goes through the length of the gearbox input shaft, is binding.  This is probably the place that gets hottest as the bike warms up.  Maybe the O-ring that normally fits into a groove inside the input shaft is dislodged or broken and the push rod is binding against it as things warm up.  Good luck.
« Last Edit: May 05, 2016, 08:31:04 AM by sib »
