Author Topic: Black Exhaust Paint  (Read 8980 times)
Black Exhaust Paint
« on: May 02, 2016, 10:12:30 PM »
I managed to score the original Black mufflers that came with my Lario, they are a bit scratched up so I want to repaint them
What is the paint they use to blacken the exhaust, anything simple like BBQ paint.
Re: Black Exhaust Paint
« Reply #1 on: May 02, 2016, 10:33:14 PM »
A powder coater will be able to ceramic coat them, it will last a very long time and won't rust.
« Reply #2 on: May 02, 2016, 10:51:48 PM »
Other than power coat, there are quite a few choices for high temperature black paint these days.  For head pipes I've been using VHT "Flame Proof" ceramic paint.  For the less hot parts I've gotten away with ordinary satin black spray paint in some cases, and some high temperature paints in others.  But barbecue grill paints tend to be dark grey and a little chalky in some cases.  Some experimenting may be in order.
« Reply #3 on: May 02, 2016, 11:41:36 PM »
Wouldn't powder coat require you to strip down to the bare metal?
« Reply #4 on: May 03, 2016, 12:24:30 AM »
 :1: Never used it on bike exhausts I must admit but on vehicles, yes.
Offline bigbikerrick
« Reply #5 on: May 03, 2016, 12:53:32 AM »
I also used the VHT flameproof stuff on my Le Mans headpipes. Its held up good, but its  kind of a chalky flat black/greyish color. I would like to have them done professionally in the future, along with the mufflers, and crossover, but I would like something a bit more  glossy black, as close to the original black chrome as possible. as far as powdercoating goes, I am pretty sure they sand /media blast the parts down to bare metal beforehand.
Rick.
« Reply #6 on: May 03, 2016, 02:32:28 AM »
I'm thinking powder coat for my Le Mans my 2 project, if you take the $$$$ hit, it would be the way to go wouldn't it ? Is the finish similar to standard and not too crass or " bright". What is considered the best thing for originality ? Huzo.
« Reply #7 on: May 03, 2016, 08:07:27 AM »
Rick, I wonder if you used the Flameproof product, or one of the others they sell.  They have another one, rated 1200 degrees F I think, that is as you describe.  The ceramic Flameproof 2000 degree stuff I got is a really nice looking satin black.  I did have to strip the pipe down to bare metal though, because remainders of the previous paint caused the satin finish to vary, giving it a mottled look.
« Reply #8 on: May 03, 2016, 08:38:35 AM »
Ceramic coating does require bare metal, the shop will blast the surface then ceramic coat.
I have head several mufflers done, very happy with the result and the mufflers will not get as hot.
Offline dguzzi
« Reply #9 on: May 03, 2016, 09:24:44 AM »
    Any idea what they blast it with? I think it has to be pretty smooth to look good.  Also do you recommend anyone for that?
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Offline drlapo
« Reply #10 on: May 03, 2016, 10:11:14 AM »
Duplicolor engine paint works for me.
They offer many colors
Offline Stevex
« Reply #11 on: May 03, 2016, 11:43:28 AM »
My pipes are satin black ceramic coated; you can't get a better black finish imo.
Offline Mike Tashjian
« Reply #12 on: May 03, 2016, 11:50:48 AM »
The Black Ceramic looks great.  How does it hold up to cleaning?  I get a lot of bugs and road tar.  Mike
« Reply #13 on: May 03, 2016, 12:32:45 PM »
just did my CX100 Bubs. I traveled it to cedar vale and back and they are still like I just did them right up to the cylinder. Very happy with that.
I recommend the Eastwood.com product which comes in either brush on or rattle can (I got both). Flat black.
They now look new.
I used emery cloth and cleaned the off rust and old coating down to metal. Then acetone, and put 3 coats on. I got the brush on stuff to do touch up if needed.
 15 Hi Temp Aerosol Flat Black 44118
Details
POR 15 High Temp Paint is capable of withstanding extreme temperatures up to 1200 degrees F and will resist cracking, chipping, and peeling. It is also extremely weather, salt and moisture resistant. Sandblasting is the optimum surface preparation. Can be used on all cars, domestic or foreign. Meets or exceeds properties and requirements of MIL C 13370.
Hi Kirby, could you post some photos of the POR 15 finish? It sounds interesting!
Rick.
Offline Stevex
« Reply #14 on: May 03, 2016, 12:40:31 PM »
I wash my pipes with car shampoo and they come up like new; the finish and lustre are very durable.
« Reply #15 on: May 03, 2016, 03:06:06 PM »
They certainly look good. :thumb:
« Reply #16 on: May 03, 2016, 04:06:40 PM »
Cannot get enough photo's of that bike
« Reply #17 on: May 03, 2016, 08:14:12 PM »
These original Silentium mufflers were in very bad shape, I spent a few hours sanding the chrome down with an orbital sander with a foam pad to get the steel smooth. The finished treated them to a semi gloss black ceramic coating. The ceramic is much tougher than powder coating. I am very happy with the end result. After I sanded the pipes the finisher went over them with a glass bead blast prior to coating.
« Reply #18 on: May 03, 2016, 11:05:43 PM »
Those are pure Guzzi sex!
Offline arveno
    • ddleathers.com
« Reply #19 on: May 04, 2016, 06:33:25 AM »
you got two choice
ceramic coating or spray paint.
do not attempt to powder coat pipes or mufflers.... it will come off.....
Offline dguzzi
« Reply #20 on: May 04, 2016, 09:41:13 AM »
Stevex, who did the work? I'd like to get in touch with them.
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
« Reply #21 on: May 04, 2016, 10:16:25 AM »
Not sure I agree. I replaced the rotted out stock muffler of my Yamaha XT500 with another good used one. Came blasted to bare metal with a light coating of primer. I took it to my local powdercoater and had them do it what they call "high temperature powder". That was two years and lots of muddy trails ago - it still looks like the day I installed it.
Offline arveno
    • ddleathers.com
« Reply #22 on: May 04, 2016, 12:51:18 PM »
Last year I wanted to powder coat the hearders of my guzzi and the powder coating shop ( which i do a lot of work with them ) did not do it because he told me he would go back to powder .
He sent me to a guy that does ceramic coating.
Maybe he did not have high temp powder and did not even bother getting it just for me.
Offline Stevex
« Reply #23 on: May 04, 2016, 12:56:58 PM »
Camcoat Performance Coatings...but they're in the UK.
« Reply #24 on: May 04, 2016, 01:14:14 PM »
Header pipes are a different matter - I wouldn't have them powdercoated even with the high-temp powder. But, it has worked very well on a number of mufflers they've done for me, including those on my Morini K2.
Offline dguzzi
« Reply #25 on: May 04, 2016, 03:29:23 PM »
Thank you Stevex
  I got what I needed from the website. Now I know the product they used and can track down a place here in the US. Perfect!
« Last Edit: May 04, 2016, 03:52:42 PM by dguzzi »
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
