Author Topic: 850T rear axle  (Read 1771 times)
Offline Guzzer
  • Retired
850T rear axle
« on: May 07, 2016, 08:11:41 AM »
I am putting together a "motorcycle in a box" which has a T3 frame but an 850T swing arm & rear end. The "thick" part of the rear axle I have doesn't come close to reaching the drum, but the axle seems to be long enough.  I'm assuming that this is a T3 axle.
Is the axle of an 850T the same as an Eldo axle or completely unique?  Can I just make a spacer or should I buy another axle?
Are the frames of the T3 & T the same except for the except for the hydraulic brake mount tab?
Thanks for any info!
1970 Moto Guzzi Ambassador riding refurbishment
1971 Moto Guzzi Ambassador
Moto Guzzi T waiting for some attention
Moto Guzzi 850 T3 for trips
Suzuki GS550 for easy country  riding
Re: 850T rear axle
« Reply #1 on: May 07, 2016, 08:47:41 AM »
Easy enough to find out if the Ambo/Eldo axle will work - try one from your Ambo or Eldo.  :wink: I think the Loop and T rear axles are the same, but I can't remember for sure.
Offline Dick
Re: 850T rear axle
« Reply #2 on: May 07, 2016, 09:18:38 AM »
T3 uses a 20mm axle. T uses a 16mm axle. There belongs a 4.5mm (+/-) washer between the axle and drum brake plate of the T. The T axle is chrome plated where the Loop axle is zinc plated, I believe. The length of Loop and T might be the same, the diameter is the same.
« Last Edit: May 07, 2016, 09:30:13 AM by Dick »
Re: 850T rear axle
« Reply #3 on: May 07, 2016, 11:43:03 AM »
It's the difference between drum and disk brakes.  The swing arm is spaced differently for the rear drive so the axle holes line up and there are other differences to accommodate disk v drum brakes.  IIRC, any early T (disk) rear axles interchange.  But I've learned to assume that NO parts directly interchange (at the swing arm/axle level) between disk and drum T's.  When I've made a T into a T3 (stupid waste of time on an 850 IMO) I pretty much tossed everything from the u-joint boot back.
