Author Topic: Is my hose clamp too long?  (Read 7128 times)
Offline SED
« on: May 15, 2016, 09:41:50 PM »
 :evil:
 :popcorn:
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline krglorioso
Re: Is my hose clamp too long?
« Reply #1 on: May 15, 2016, 09:45:51 PM »
Seems fine to me.  Excess is not in the way of anything, as far as I know.
Ralph
Ralph
2004 Moto Guzzi Breva 750
2017 Honda CB-500F
Online John A
« Reply #2 on: May 15, 2016, 09:51:44 PM »
That will cause the mirrors to vibrate and things will start falling off. Seriously I'm sure it's fine  :grin:
« Reply #3 on: May 15, 2016, 09:54:39 PM »
 It'll crack your CARC  :shocked:
Offline SED
« Reply #4 on: May 15, 2016, 09:55:56 PM »
So no exhaust leaks? :grin:
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline ITSec
« Reply #5 on: May 15, 2016, 10:12:16 PM »
If a shorter one was on hand and would do the job, then yes - it's too long.
If not, and this one did the job, then it's just right!
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #6 on: May 15, 2016, 10:38:22 PM »
I've had 1 a tad shorter just to see if it ever moved.  At the same time before I got around to adding a hose clamp, when I went to replace a filter it wasn't even finger tight.   :shocked:
« Last Edit: May 15, 2016, 10:39:15 PM by Arizona Wayne »
« Reply #7 on: May 16, 2016, 01:15:04 AM »
 Hose clamps that are too long make your butt look too big.
Online rodekyll
« Reply #8 on: May 16, 2016, 02:11:51 AM »
It only needs to be long enough to get around the filter and a karma bell.  But I can't see the excess hurting anything.
« Reply #9 on: May 16, 2016, 02:22:43 AM »
Lets ask our own Guzzi factory expert and quantum mechanic, Knuckles Dragini, his opinion!
"Feels Justa Right!"  :thumb:
« Last Edit: May 16, 2016, 02:24:04 AM by Penderic »
Online Dukedesmo
« Reply #10 on: May 16, 2016, 05:05:45 AM »
As long as it's not at the end of it's adjustment, it'll be fine. You could always cut some of the excess off if it bothers you or you want the weight reduction...
Le Mans II
Ducati 916
Ducati M900
Online Wayne Orwig
« Reply #11 on: May 16, 2016, 09:14:36 AM »
Wrap it in duct tape.
:coffee:
« Reply #12 on: May 16, 2016, 10:14:38 AM »
The excess length will start creating a harmonic imbalance of the sump.  That vibration will work it's way up the crankcase to the transmission where you will feel it as tingling in the toes.
You can stop the vibration by dragging your toes on the pavement repeatedly.  This will wear down just enough of your boot to upset the harmonics.
Once that happens the bike will run smoothly.
If you fail to wear off a specific amount of rubber from the boot the harmonics will increase until the hose clamp breaks, sending pieces of metal through the oil filter, leading to catastrophic engine failure.
(in case you could not tell, this is in jest)  :)
« Reply #13 on: May 16, 2016, 06:12:59 PM »
Too long?
Nope, You probably dropped the other one when you opened your retention kit. There's another 3/8 inch clamp to hold down the excess of the first clamp and then if you look carefully - there's a zip-tie for further securing that one and a U.N. seal to ensure no tampering...
Todd.
Offline Michael D
« Reply #14 on: May 16, 2016, 07:04:55 PM »
Come on guys, be serious.  A bigger filter is the solution.   :wink:
74 V7 Sport
98 V11 EV
Tulsa, Oklahoma
Offline SED
« Reply #15 on: May 16, 2016, 07:13:23 PM »
I will do this quick before the harmonics cause an exhaust leak.  Or worse, cavitation in the oil pump!   :boozing:
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline Scud
« Reply #16 on: May 16, 2016, 07:15:17 PM »
Am I the only one immature enough to think that the title of this topic is an open-invitation for answers in poor-taste, such as "Only if your hose is too short."?
  :evil: :popcorn:
1989 Moto Guzzi LeMans
2017 Husqvarna 701 Enduro
2017 Moto Guzzi Stelvio NTX
2020 Yamaha TW200
« Reply #17 on: May 16, 2016, 07:20:38 PM »
  :evil: :popcorn:
I was thinking: "If you're using a clamp, you're probably doing it wrong" but then, that could be Guzzi content even in an off-color scenario.
"What, hell, I don't need that, got me a hose clamp out in the garage that'll do just fine... after I clean it up a bit."
Todd.
Offline lucian
« Reply #18 on: May 16, 2016, 07:23:14 PM »
Many unwanted pregnancies can be traced to an over  sized hose clamp , but for this application you should be ok.
Offline SED
« Reply #19 on: May 16, 2016, 07:37:21 PM »
This people on this forum are awesome!  I knew you would all provide exceptionally clever help.  It's been said many times that there is amazing amount of expertise on WG.  There is also exceptional humor.  Thank you!   :afro:
Do you think I should consult my doctor?   :whip2:
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #20 on: May 16, 2016, 07:40:26 PM »
 Well , I did stay at a Holiday Inn Express ...
« Reply #21 on: May 16, 2016, 07:40:53 PM »
Do they still make those?
 :grin:
Offline Idontwantapickle
« Reply #22 on: May 16, 2016, 08:04:22 PM »
 :grin:
The short answer Cam is no, they don't. :evil:
BUT......it is a little known fact that the whole reason the CARCs have external filters is that if someone were to put too long a clamp on the filter it would cause catastrophic deCARCerization. Nobody wants that now, do they?
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline fatbob
« Reply #23 on: May 16, 2016, 08:16:23 PM »
You need an outsider from Harpers!
Bob Lower
'07 Norge
'01 K1200LT
'10 Thunderbird
'88 FLHS
'79 R100T
'03 R1150RT
'07 GTS 250
« Reply #24 on: May 16, 2016, 08:18:21 PM »
 Hunter said "deCARCerization"  :laugh:
Online rodekyll
« Reply #25 on: May 16, 2016, 10:15:24 PM »
Has it been four hours?
« Reply #26 on: May 16, 2016, 11:15:35 PM »
It's not a side effect - it's a scheduling conflict.
Todd.
