Author Topic: Breva 1100 Fuel Injector Query  (Read 2132 times)
Offline Tinkerfreak
« on: May 21, 2016, 06:07:57 PM »
I've decided to change out the fuel line on my 07 Breva 1100 as it had developed a small leak near the t-fitting. I podged a repair with fuel injection line and thought it was time to correct the issue. Problem is I can't figure out how to separate the injector from the line. Is it just held in place with friction or is there something I am missing. There is no info in the manuals and did a search here with no joy. Any assistance will be greatly appreciated.
Cheers
beetle
Re: Breva 1100 Fuel Injector Query
« Reply #1 on: May 21, 2016, 06:31:21 PM »
Pretty sure they're just barbed fittings and the hose is heated to shrink down for a leak-proof seal.
Offline Tinkerfreak
« Reply #2 on: May 21, 2016, 06:42:53 PM »
It's not the hose that I am trying to remove it's the Injector itself. The new line came with the end fitting but I need to remove the Injector from the old line and can't figure if it is friction fit by an o-ring or a circlip of some sort.
Cheers
beetle
« Reply #3 on: May 21, 2016, 07:37:17 PM »
Sort of friction fit. The O-ring holds it in place. A twist and pull action should remove it.
beetle
« Reply #4 on: May 21, 2016, 07:38:23 PM »
Don't yank on them. Be gentle.
Offline Tinkerfreak
« Reply #5 on: May 22, 2016, 08:28:37 AM »
Thanks Beetle, much appreciated.
Cheers
