Author Topic: Bought a new V7II Stone, one small issue  (Read 12042 times)
Offline DaSwami
« on: May 26, 2016, 02:20:27 AM »
He &(@#$$% repositioned the front forks on mine, making the front sit exactly one inch lower than stock.  I'm guessing he was thinking about making my bike one of his "lowered" specials and then changed his mind.  The rest of the bike looks stock.
Anyone know how to return the forks to the factory setting?  The tops of the fork tubes stick out of the top of the triple tree/clamp...stock has them flush with the clamp.
Thanks,
Swami
« Last Edit: May 26, 2016, 03:37:28 PM by DaSwami »
Re: Bought a new V7II Stone from Moto International, one small issue
« Reply #1 on: May 26, 2016, 02:45:19 AM »
Support bike under sump so wheel is off the ground, undo pinch bolts, wriggle forks down, retighten pinch bolts.
Offline DaSwami
« Reply #2 on: May 26, 2016, 02:49:50 AM »
Thank you sir...where are the pinch bolts?  I'm green at this stuff.
« Reply #3 on: May 26, 2016, 03:18:13 AM »
The upper fork tubes pass through clamps in the upper and lower triple trees.  If you look you will see that those passages are slotted.  The slots allow the clamps to pinch the tubes so's they stay put.  Somewhere in the area of those slots will be one or more large-ish (6mm allen head?) pinch bolts. Those are what you want to loosen.
When tightening, if there are more than one bolt at a slot, the bolts must be cinched down evenly, as a unit.  I think there's another topic out there talking about adjusting valves that way where it doesn't matter.  Here it does.  Once one is tighter than the other, the other is ineffective.  Remember, these are PINCH bolts.  Snug and a nudge is plenty.  overtightening them can have bad effects.  I like to use two identical rachets and snug them up together.  As long as you're not overtorquing, the absolute torque value isn't as important as even pinching.
Offline DaSwami
« Reply #4 on: May 26, 2016, 03:27:06 AM »
OK, I see the pinch bolts on my CB1100, Scrambler, and TW200 plain as day.  On the V7II, I can see the threads but the heads of the bolts are hidden under the instrument cluster somewhere.  So there is some disassembly required.
On a related note, this pisses me off to no end.  Why why why mess with the factory stock settings on a new bike.  As you said evenness of torque and I'm sure equal fork tube length are critically important.  I'm not qualified to to do this work, I just drove 800 miles round trip to pick up this bike and it's been modified from stock at the dealer.  I think MI or Piaggio should send a tech to my house and make this right.  Why do I want a bike whose already limited fork travel has been reduced by 20% for no good reason???  It's just really stupid.
Damn, I'm in a bad mood now
« Reply #5 on: May 26, 2016, 04:07:58 AM »
I don't know the specifics of your bike, so I can't say what all is involved.  Getting the forks even is not a big deal, although as you say, getting to that point might be more of a deal.
Are you sure this happened at the dealer?  I don't know one way or another, just asking.
And finally, is this a problem with the bike's rideability, or is it more of a matter of principle?  I'm only asking this because you note that it's 'different', but you don't indicate that it's necessarily 'bad'.  The part about losing 20% of your fork travel doesn't make sense, though.  The steering has been quickened, but the travel hasn't been shortened unless the fork sliders are hammering against the lower tree on every bump.
A lot of folks do that mod to improve handling.  I'm always running mine up and down the trees just to see what happens with different loads and tires and stuff.  It's really no big deal, and one you'll want to get comfy with if you're 800 miles out.  I'm carrying a jack and hammer with me on the trike right now just so I can smack the tubes around from beside the road.
Offline Das
« Reply #6 on: May 26, 2016, 04:44:16 AM »
For what it is worth I have had that mod recommended to me by one of the current Godfathers of Guzzi as a way to improve the handling on a V7.
Das
ponti_33609
« Reply #7 on: May 26, 2016, 05:30:17 AM »
I bought my bike from MI as well.  Dave is one of the easiest and IMO nicest people to deal with..............I bet if you call him he could at least fill you in if he knows anything and walk you thru the fix step by step.  He contacted me 9 months after I bought my bike just to say hi and see how I was doing.
Offline kevdog3019
« Reply #8 on: May 26, 2016, 05:37:42 AM »
For Gods sakes ask Moto International!  I might add that I'd leave it be until I asked why. You're likely better off with them through the trees. MI knows a thing or two. Your travel should not have changed.
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
Offline jackson
« Reply #9 on: May 26, 2016, 06:20:25 AM »
Unless you're having some type of handling problem due to the lowered forks, your bike probably handles better than if the forks were all the way up. I wouldn't touch them until you have (at least) called the dealer to ask why they adjusted them (just to ease your mind).  As Rodekyll said, be VERY careful when tightening pinch bolts if you DO decide to adjust them because you could be opening up Pandora's Box by costing yourself a bunch of $$$$ to repair the damage if they're over-tightened.
NO longer can ride
« Reply #10 on: May 26, 2016, 06:24:23 AM »
A quick call to Dave at MI will have this "issue" sorted with ease.  Like others have said after your phone call you may be more than happy to keep them in the current position.
It puzzles me why you haven't called?
Offline Dean Rose
    • Twin Valley Riders
« Reply #11 on: May 26, 2016, 06:38:16 AM »
Thanks,
Swami
If I were you I wouldn't go trashing one of the best and smartest Moto Guzzi dealers there is. Call MI and speak to them before you blow a gasket.  :grin:
Dean
Magnolia '02 EV
Sophia '06 Breva 1100
Offline DaSwami
« Reply #12 on: May 26, 2016, 11:27:19 AM »
I emailed Dave last night as soon as I saw it and I will call him shortly.  Yes he is a very nice guy.
Yes, I blew a gasket because I don't like my bikes messed with, and I had a few beers when I made the discovery.  I'm not a "farkler" or modifier, the bike is perfect to me as is.  I even gave him a little pushback when he told me he was uploading the latest ECU map to the bike, my other V7 II runs perfect as is out of the box.  sometimes new "maps" cause issues.
You all are right, I'm going by the length of the fork gaiters, they are a full one inch shorter than my other bike, I assume a gaiter gets shorter via suspension compression???   That's where I come up with shortening the travel.
I guess we'll see where this goes
Offline kevdog3019
« Reply #13 on: May 26, 2016, 01:29:25 PM »
If you traveled 800 miles with the forks through the clamps and didn't feel a thunk up front you should be good. Yes, the total travel distance of the shocks is less by however much they were moved through the triples. However, you have WAY more travel than you need on a fork. I'm guessing you use 2.5-3" of fork travel and you have about 6-7" currentlybetween the top and bottom. The gators are compressed because the space they sit between is smaller, the forks are NOT compressed(just moved). You are fine trust me.
« Last Edit: May 26, 2016, 01:33:14 PM by kevdog3019 »
'86 V65 Lario
Offline DaSwami
« Reply #14 on: May 26, 2016, 02:15:20 PM »
Thanks for the feedback. I trailered the bike 400 miles did not ride it yet.  I'm having a hard time wrapping my head around this.  But that is why I post about this.
« Reply #15 on: May 26, 2016, 02:21:16 PM »
Only if the travel is more than the remaining exposed fork tube length, which is possible, but unlikely.
Offline acogoff
« Reply #16 on: May 26, 2016, 02:23:36 PM »
     My feeling is if you have to ask how to lower the fork tubes, maybe you should have someone with experience (I.E. Moto Int.) do it as this is a very critical area and you do not want them to come loose or over torquing the bolts would also make for a very bad day.
Marshall County Minnesota USA
Offline Steph
  • Cali Stone/ LM3
« Reply #17 on: May 26, 2016, 02:33:20 PM »
Let me get this right, you're posting here bitchin' about a dealer ( & in the subject title!) THEN send them an email for help? Let me know how it works out. I need to learn from you sir  :laugh:
Offline Curtis Harper
    • Harpers Moto Guzzi
« Reply #18 on: May 26, 2016, 02:37:25 PM »
This is always the legal disclaimer. Sorry I try not to be negative, but really?
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
Offline sib
« Reply #19 on: May 26, 2016, 02:58:13 PM »
Moto International offers to set up bikes specifically for shorter riders.  See for example
http://www.motointernational.com/blog/news-and-events/post/another-short-v7-stone-is-available-now
Perhaps yours was one that they had set up for a shorter rider?
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
« Reply #20 on: May 26, 2016, 03:27:20 PM »
Dang, MI didn't set out to shaft you. This is a minor thing. I can understand being a little miffed but it isn't like they decided to screw with you right?
You know, when you pick up a new bike, the dealer (for sure MI does it) goes through a checklist to make sure it's ready to go AND you sign the form saying all is okay. Its your job to inspect and accept delivery and if something isn't right, have it adjusted before you accept the bike.
Things happen, this is one if them.
Might I suggest you kindly ask one if the mods to delete the entire thread so you can start over, one part being letting MI know you were just frustrated and now with a cooler frame if mind, would they be so kind as to help you get the forks the way you want them.
Just a thought.
Online Chuck in Indiana
« Reply #21 on: May 26, 2016, 03:34:03 PM »
Only if the travel is more than the remaining exposed fork tube length, which is possible, but highly unlikely.
FTFY
Offline DaSwami
Re: Bought a new V7II Stone, one small issue
« Reply #22 on: May 26, 2016, 03:43:06 PM »
Fixed the title of the thread.
Not saying they were trying to screw me, just saying it was unnecessary.  Leave the bikes suspension alone at the factory specs.  What's wrong with that??
It is a subtle difference that was not easy to catch, until I looked at it next to a "normal" V7II.  In reality, I shouldn't have to "catch" this as it should not have been done to begin with.
Ok, the beer disclaimer, that is not a justification for my indignation, just for ranting about it here. I still would be pissed about it.  At least I admit it.  Yes, should never post when drinking and pissed, I broke my rule. Bad call.
« Reply #23 on: May 26, 2016, 03:59:42 PM »
well, now I'm confused.  In the OP you said you can see the forks sticking out the top of the trees by one inch, and that's how you know they've been altered.  Then you say you're going by the fork gaiters, which seem shorter on a different year bike and may be an apples to oranges comparison.  Finally you say that you noticed because it appears different than an unlike model when they're side-by-side.  You cap it off with a claim about reduced fork travel, which is simply not the result of what happened.
I asked in my first response if you are sure that this actually happened at the dealer.  Now I'm questioning if it happened at all.
I also asked if you noticed anything BAD about the alleged mod, and even though you say you've got another V7II to compare to, you've said nothing about the quality of the handling.
In short, I think you might have begun this topic in haste, based on something that appears different between two unlike objects.  Perhaps pulling it and starting over when you have some more information would be the more fair approach.  I'm not saying this stuff didn't happen.  I'm just saying that if it did, nothing here yet confirms it.
$0.02
Offline DaSwami
« Reply #24 on: May 26, 2016, 04:08:00 PM »
$0.02
Now you are being an a**hole
The bike has been altered, 100%, at the dealer.  I have an IDENTICAL bike to compare it to side by side.  The length of the fork gaiter is 1" shorter and the fork tubes stick out 1" out of the top of the triple tree/clamp or whatever it is called.  Given the gaiters are 1" shorter, I ASSUMED that was due to compressed forks and thus the claim of reduced fork travel.  I have not ridden the bike yet.  I just trailered it home yesterday.  Would you like me to post some pictures??   Maybe that would clear it up for you
« Reply #25 on: May 26, 2016, 04:09:39 PM »
PM'd you.
Offline kevdog3019
« Reply #26 on: May 26, 2016, 04:09:56 PM »
It was unnecessary for you that is correct. We still don't know why it was done prior to your purchase and that is why you need to talk to them. There is likely a good story behind it and even a small chance they didn't even mess with it, we don't know??  I'd be more curious than upset. If they have good reason and it was a mistake not to put it back to stock for you, I'd ride it and compare to your other V7. I bet I'd like it better. You may be a lucky guy!!
'86 V65 Lario
Offline DaSwami
« Reply #27 on: May 26, 2016, 04:13:14 PM »
It's the principle of the matter.  If you buy a 4x4 pickup truck with factory suspension height, how would you feel if you found out the dealer lowered the suspension a couple of inches "for better handling"?  Then your slightly larger shiny new tires don't fit and you have no idea why, because factory specs allow for the larger tire size.
Maybe it's no big deal to ya'll, and that's fine.  To each their own.
Offline DaSwami
« Reply #28 on: May 26, 2016, 04:20:55 PM »
OK, I will be calling them shortly.  Thanks
« Reply #29 on: May 26, 2016, 04:27:58 PM »
[snip]
No, sir, it's entirely you.  All I've done besides offering you solid advice and support, is to point out that you've told three different stories while dodging straight answers on pertinent questions.  You on the other hand are bashing a dealer based in ignorance and on a supposition that at this point you seem to be pulling out of your ass.  I've tried to coax you toward a reasonable position, but based on this crap, we're done.
