Author Topic: knocked my rings the floor, which way is up?  (Read 2058 times)
Offline amamet
« on: May 29, 2016, 04:45:33 PM »
did exactly what i tried not to do, managed to drop my 3 rings off the bench.  79 v1000 g5.  can't tell which was is up on the rings nor which was on top, all the profiles look the same no matter how hard i look at them.  they have approx 26k miles on them.  does it matter how they are place back onto the piston?
thx
allen
Re: knocked my rings the floor, which way is up?
« Reply #1 on: May 29, 2016, 04:52:42 PM »
Yes. Top ring should be chrome assuming cast iron bore, second ring ring is a torsional taper-face semi scraper and should have a slight step on one side, the step goes towards the skirt of the piston. Oil ring is almost certainly ambi-sidestrous. Is it one piece or three piece?
Offline normzone
« Reply #2 on: May 29, 2016, 04:57:51 PM »
I am unable to form an amusing comment regarding trying putting the piston in upside down, but if I come up with one I'll let you know.
Offline amamet
« Reply #3 on: May 29, 2016, 05:08:51 PM »
installing  the piston upside down would be funny if at all possible
Offline amamet
« Reply #4 on: May 29, 2016, 05:11:53 PM »
so i found my magnifying glass to actual see these closely.  the top ring has printing on one side by the gap, i assume this is the top.  the second ring has a step, i assume this is the bottom and the oil ring also has printing on one side by the gap, i also assume this is the top.  am i correct in these assumptions?  and yes, i know about assuming (have seen that odd couple episode multiple times)
thx
allen
« Reply #5 on: May 29, 2016, 05:18:53 PM »
Correct.
Offline amamet
« Reply #6 on: May 29, 2016, 05:27:40 PM »
thx again
Online lucian
« Reply #7 on: May 29, 2016, 05:37:28 PM »
Pete , you never cease to amaze me. You continue to be one of the best aspects of the guzzi ownership experience. :bow:
