Author Topic: Fuel filter  (Read 1099 times)
Offline Steve Cas
Fuel filter
« on: May 31, 2016, 01:19:27 PM »
This filter looks pretty clean compared to the intake screen. My son's Jackal sat for a year outside under a tarp while he was on active duty. I changed the fuel filter and pump. The tank looks OK. I need to change a couple of hoses before I try to start it.
Offline normzone
Re: Fuel filter
« Reply #1 on: May 31, 2016, 01:30:26 PM »
Nice surgery on that filter cannister.
I wonder why they put that big hex on the end if it's not designed to be taken apart ?
Re: Fuel filter
« Reply #2 on: May 31, 2016, 02:13:07 PM »
Check the little drain hole underneath the recessed fill cap, they have a nasty habit of plugging off and sending
rain/wash water into the tank, a sod to fix.
The filters very clean, the one on my EV was so plugged up the fuel was unable to get to the injectors, it would run for a while then just bog down I back flushed it at the KOA in Denver
then again when I got back to BC, the photos show the BC flush, I bet there was 5 times as much came out the first time.
This is all caused by the moat drain plugging off to sent water into the tank.
« Last Edit: May 31, 2016, 10:08:25 PM by Kiwi_Roy »
Re: Fuel filter
« Reply #3 on: May 31, 2016, 05:29:49 PM »
I'll take the question seriously -- it's to put a wrench on to hold the can while you unscrew the fittings.
