Author Topic: Are these stock bars?  (Read 1817 times)
robdrobd
« on: May 31, 2016, 04:32:48 PM »
After about 3 months I'm a little disappointed in the riding position of my 2013 v7 Stone. Then I took a look online and maybe found the problem. Are these stock handlebars? If not, maybe the stock ones have more rise and will keep me from leaning forward so much?
« Last Edit: May 31, 2016, 04:33:21 PM by robdrobd »
Re: Are these stock bars?
« Reply #1 on: May 31, 2016, 05:06:08 PM »
If you need a different bar it doesn't matter if this one is stock or not.  The better question is "These bars suck -- what are my options?", and the answer is that hose are standard 7/8 bars.  You can use almost anything you like in place of them.  Go to your local UJM store and ask if you can haul a few pairs (one at a tmie) out to the parking lot and hold them up to the bike.  Take the winner home.  The changeout, provided your calbes still fit, should be less than an hour.
If you find a bar that's not quite right you can clamp it to a wood deck and use pipe cheaters to change the bends.
Good luck!
[edited for some horrific spalling]
« Last Edit: May 31, 2016, 05:27:02 PM by rodekyll »
« Reply #2 on: May 31, 2016, 05:17:59 PM »
If I was sitting on your bike I would probably find your handlebar perfect in that I want to lean forward some just like on my 750 Breva.  :smiley:
robdrobd
« Reply #3 on: June 01, 2016, 09:39:00 PM »
I'm thinking about buying the corbin gunfighter seat. I think I'm wait and see if the riding position improves with the seat and bars
« Reply #4 on: June 01, 2016, 09:42:13 PM »
Try one thing at a time.. if the seat is bad try that first even if it costs more than bars, you already know you need a better saddle..
Offline normzone
« Reply #5 on: June 01, 2016, 10:09:24 PM »
" If you find a bar that's not quite right you can clamp it to a wood deck and use pipe cheaters to change the bends. "
The most expensive part of this is that first he'll have to build a deck.
Of course, it will have to be a big one...you know what the ladies say.
