Author Topic: Help needed, Berwick, PA  (Read 10911 times)
Offline guzziknight
« on: June 01, 2016, 04:34:08 PM »
Hi all,
I'm on my road trip, 3rd day. My 98 EV is acting up. It's hesitating in most gears, at varying speeds. I thought it might be a transmission issue, but the it began having starting problems as well. It also seems very down on power.
I'm going to try to make it to the Guzzi dealer in Goshen, NY first thing tomorrow to have them look at it. Hopefully it'll make it there, which I think it will.
Is there anyone near Berwick that has the diagnostic software and the skill to look at it tonight? I know it's a long shot, but figured I'd ask.
If so, call me at 770-634-6967.
Thanks,
Yaniv
Blue Knights Georgia VII
Iron Butt Association #18342
Moto Guzzi National Owners Club #L-773
Four Wheels Move the Body. Two Wheels Move the Soul.
Calling an Illegal Alien an "Undocumented Immigrant" is like calling a drug dealer an "Unlicensed Pharmacist."
Atlanta, GA
Offline guzziownr
Re: Help needed, Berwick, PA
« Reply #1 on: June 01, 2016, 04:41:15 PM »
I am very close to Goshen if I can be of assistance.  The tech there has plenty of experience so he should be able to help you.
P.M. if you get there tomorrow.  I may or may not be working but I will be finished by 3:00 regardless.  DW
LaMojo
« Reply #2 on: June 01, 2016, 04:45:21 PM »
It could be a spark plug issue.
Online Vagrant
« Reply #3 on: June 01, 2016, 06:17:29 PM »
did u bring your extra TPS with you
Offline vintage53
« Reply #4 on: June 01, 2016, 06:21:10 PM »
Hello.
If you are staying in PA tonight.
You may want to try reaching out to Eurosports. In Cooperburg ,PA
Closer than Goshen NY.
A Guzzi dealer.   I recommend them.
Ph. 610  282 9300
1977 Lemans
2004 V11 Coppa Italia
2010 California Vintage
« Reply #5 on: June 01, 2016, 07:01:05 PM »
Hesitating do you mean missing?
Does it seem more like starving for fuel, dies on a hill, does the pump seem extra noisy, mine had a plugged fuel filter I let the fuel run out of the filter backwards, lots of rust
Missing? get hold of a multimeter and measure resistance from plug cap to chassis, should be 5 - 8 kOhm, mine had shitty carbon core HT lead that was not making contact at the coil end.
Online fotoguzzi
« Reply #6 on: June 01, 2016, 07:28:09 PM »
I once had similar problem. turned out to be plug wire. you could try cutting down the plug end an inch or so (if it's long enough) and re-seat the cap..
also could be a tank vent problem?
« Reply #7 on: June 01, 2016, 10:45:13 PM »
I'll go with a gas filter change first.
« Reply #8 on: June 02, 2016, 04:22:30 AM »
The filter can be cleaned by the roadside by simply backflushing it with the gas trapped inside.
Check if the filter is plugged first by removing the return line at the steering column, direct it into a bottle.
If it's plugged you will just get a dribble of gas as the pump primes.
(on the 98 EV the pressure regulator is bolted to the chassis under the tank, the return line is low pressure high volume)
Offline Zoom Zoom
« Reply #9 on: June 02, 2016, 05:08:45 AM »
That was my thought as well.
NAPA Gold 3008 is the filter IIRC. Needs some duct tape around the body to tighten in the clamp but otherwise is correct.
John Henry
Offline guzziknight
« Reply #10 on: June 02, 2016, 10:39:56 AM »
90% of it was an air leak at the right cylinder intake boot. Fixed that. Still has a little hesitation which I think is the TPS. Should be good for now. Thanks all!!
Atlanta, GA
Online pehayes
« Reply #11 on: June 02, 2016, 12:20:42 PM »
How was that leaking?  Throttle body backed away from the boot?  Boot backed away from the manifold?  Such things happen because of high pressure of an internal backfire.
With variable and constant missing, my first thoughts were spark secondary wires.  Both of our 98EVs had chaffed the right cylinder spark wire exactly where it squeezes between the cylinder and the old hole/plate where a distributor used to reside on earlier motors.  The wire was jammed in tight and chafed until it started to short.  Regina's was lighting up like a Christmas tree.  Once I solved hers, I inspected mine and caught it before the shorting started.
« Reply #12 on: June 02, 2016, 02:44:19 PM »
After lighting up my leg for a day of rain I ran my plug wires through plastic tubing.  I also routed them around the front of the valve covers instead of up my legs.
Offline guzziknight
« Reply #13 on: June 03, 2016, 06:37:07 AM »
 After all that, I think the bike is toast. Later in the day, the bike became harder and harder to start. I got stuck in a traffic jam for about 60 minutes, and the bike got so hot, I could smell the clutch frying. Bike ran even worse after that. It's now parked at a friend's house and we rented a car to continue the trip, or part of it at least.
I'm now trying to figure out how to get the bike and trailer back to Georgia. Not sure I'm going to bother trying to fix it at this point. I'm pretty sure I did more damage to it yesterday. May just donate it to charity up here and not waste the money bringing it back.
Atlanta, GA
« Reply #14 on: June 03, 2016, 04:54:33 PM »
Ouch!
Online pehayes
« Reply #15 on: June 03, 2016, 06:08:16 PM »
Replacing clutch friction discs is a time-consuming but relatively cheap exercise.  I'd offer to buy it from you but it would cost me $1500 in fuel just to tow it home.
« Reply #16 on: June 03, 2016, 06:11:59 PM »
 700 gallons of fuel ??? WTH are you driving Patrick  :shocked:
Offline guzziknight
« Reply #17 on: June 03, 2016, 07:47:13 PM »
The clutch was replaced last year. No idea if I fried it, the engine, tranny, or something else. Either way, I can't ride it back to Atlanta, and found it'll cost me $1300 to rent a truck to haul it and the trailer home. The bike probably isn't worth that, especially since I'd then have to spend money to fix it.
I'm in Boston continuing our trip and trying to figure out a solution.
Atlanta, GA
LaMojo
« Reply #18 on: June 03, 2016, 08:13:50 PM »
Maybe a simple clutch adjustment will put things in order.
Online fotoguzzi
« Reply #19 on: June 03, 2016, 10:20:40 PM »
Maybe you should get a proper diagnosis from a reputable dealer before throwing in the towel?
aside from the clutch smell...
if a simple TPS or cam/crank sensor replacement fixes it.. it would be a shame to abandon the poor thing..
Swarf on the crank sensor?
« Last Edit: June 03, 2016, 10:30:04 PM by fotoguzzi »
Online pehayes
« Reply #20 on: June 03, 2016, 11:36:15 PM »
San Francisco to Boston to San Francisco is 6196 miles.  My camper van gets 14mpg when I tow.  443 gallons at $3 per gallon.  Add some tolls and I have to sleep somewhere.  Oh, wait. That's right.  You're not all in California paying $3 per gallon when lucky.
« Reply #21 on: June 04, 2016, 01:15:23 AM »
I understand the feeling of defeat a guy gets when he's that far from the barn and the horse is limping.  It seems no longer worth it.  But a day or two to sort it out and you might have a different outlook.  We don't know anything more than it's running poorly and stinking.  And really that's all it tells us.  It could mean anything or nothing.
Considering the possible costs I agree that you need a better idea of what just happened before making your next move.  If it's a $1500 proposition to get it home and it's totaled, then you should leave it there and try to sell it as damaged.
If it's a $50 fix and you can drive it home . . . .
 I'm putting my money on a combination of not having found the original problem and that problem acting up moreso in the traffic jam.
I lost power completely on a '68 BSA once passing through Spokane on my way to Yellowstone.  With no tools, book, experience or clue about BSA's beyond spelling it, I took almost a week to sort it down to a bad zener diode, and after several adventures, many miles of walking in extreme heat, and the sympathy of a 'lil cutie who lived in an efficiency apartment overlooking my efforts, I got it going again.  I became determined to out think Joe Lucas and his legions of darkness.  NOTE:  Empire Cycle was in business back in '72 . . .
   So all fixed up and smarter for it, I took some roads not taken and ended up finally in 3rd gear pushing my way over the summit of Lolo Pass.  The bike was running smoothly -- probably the best it ever had -- and as I passed under the sign that said "Welcome to Montana", the center portion of the A65's left con rod beat me over the state line.  That was the same con rod that Cisco Gonzales of Gonzales Motors in Tacoma charged me $425 to replace not a thousand miles ago.  After Spokane and now this, I was determined to understand mechanical things and keep my own stuff running.
     Still undaunted, I coasted as far down the pass as gravity would take me and found a comfy turnout.  I witnessed my first display of Northern Lights.  I thought it was Calgary on fire until someone pulled over to also watch and explained what I was seeing.  I stayed the night there, determined to figure out how to photograph the northern lights, mostly on account of the guy who explained them to me assured me that they could not be captured on film.
The next morning a drunk cowboy (yeah, I said "morning" and "drunk") helped toss it into the back of his pickup and took all but my last $5 to haul me to Missoula.  He spent all but about $5 of that on booze along the way, so we didn't get to the bike shop in Missoula until after midnight.  He unceremoniously dumped the bike in a dirt pile behind the shop and disappeared into the night.  I knocked on the door of the house attached to the bike shop where loud party music blared.  A biker answered, listened to my story, handed me a joint and a beer, and told me to go away until tomorrow.  So  I made camp in the dirt pile next to the bike and spent the night smelling Castrol 20/50 and listening to Cheech explain to Chong that "Dave's not here, man!" endlessly, for the rest of the night.  Well, Dave certainly was here, and the mosquitoes rejoiced.
    I spent about 6 weeks in Missoula working in the stockyards and washing dishes trying to get the money together to repair the Beezer.  I wasn't getting anywhere.  The bike shop pushed the hulk into the back room and I headed for Yellowstone and the Park Service.  There I made enough to buy a VW van by doing road matienance, perimeter patrols, trails maintenance, and fire fighting under the job description of "truck driver, which is the one thing I never did.  At the end of the park season I'd learned a heck of a lot about all that stuff and pushed snow back to Missoula to get my bike.  All that remained was the stripped frame, identifiable because of the awful paint job I'd inflicted on it.  The shop claimed to have no knowledge of me or the bike, and offered to explain it more emphatically if I persisted with my objections.  I became determined to never take anything to a shop again.
That trip took almost a year to complete, and it wasn't until a decade later that I finally did get a bike from the coast to Yellowstone and back -- in a week of easy travelling on my Ambassador.  But I wouldn't have missed the experience for anything.  I've become an accomplished northern lights and night photographer, I've not had anything in the shop since, I've had a career as a mechanic, and a vehicle electrician, and came to understand stuff well enough to help out others and design and build my own motor trike concept.
All because my piece of shit motorcycle kept breaking down and stranding me.  So hang in there.  These things can work out even when they don't seem to be.  :)
Offline davedel44
« Reply #22 on: June 04, 2016, 04:28:46 AM »
Wonderful story Roadkill.
Entertaining and insightful  :bow:
Dave
Galveston
« Last Edit: June 04, 2016, 04:31:02 AM by davedel44 »
Bambino- 2013 V7 Stone
Online tazio
« Reply #23 on: June 04, 2016, 08:24:57 AM »
Wow Roadkill, just wow! :bow:
My take away is  "dig the experience", don't freak out, keep on truckin'.
er, I mean biking! :thumb:
We are all there with you Guzziknight.
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
Offline CalVin2007
  • fickle old fool
« Reply #24 on: June 04, 2016, 09:23:56 AM »
  I read quite frequently about folks shipping a bike across the country for 500-700 bucks with one of the bike transport companies. Why doesn't it apply in this case? Seems a workable solution to the problem at hand....
  Edit: I see the other thread has addressed this issue with the same suggestion.
« Last Edit: June 04, 2016, 09:25:19 AM by CalVin2007 »
'07 CalVin
 '79 TT500
 '78 SR500
 '80 SR500
Offline Dilliw
« Reply #25 on: June 04, 2016, 10:20:37 AM »
Sorry to hear about this.  When I saw you at TWS you were really excited about this trip but hey it goes on.  Just a curve ball on the road!
George Westbury
Austin, TX
« Reply #26 on: June 04, 2016, 01:01:04 PM »
My thoughts too.
Offline johnr
« Reply #27 on: June 04, 2016, 05:41:23 PM »
I understand the feeling of defeat a guy gets when he's that far from the barn and the horse is limping.  It seems no longer worth it.  But a day or two to sort it out and you might have a different outlook.  We don't know anything more than it's running poorly and stinking.  And really that's all it tells us.  It could mean anything or nothing............ .........
..................A ll because my piece of shit motorcycle kept breaking down and stranding me.  So hang in there.  These things can work out even when they don't seem to be.  :)
Loved that tale Roadkill. Pity about the Beeza though.  (I suspect a blocked up sludge trap may have accounted for your con rods)
I am another who is very reluctant indeed to use a bike shop, for reasons similar to yours, and others.
To the OP, I would also be reluctant indeed to give up on the bike at this point, especially as the fact that you own it means that you like it, at least in principle.  I can understand though the emotional temptation  to do so.
As for getting it home Check out all the possibilities. There are trains and freight lines amongst other things. Perhaps even store it somewhere  and do another road trip yourself in the not to distant future to retrieve it?  You might need a mate with a ute or a van.  Or even buy a cheep van. They can be useful things. Such retrieval trips can be fun in themselves.
Chin up Yaniv. Some trips go bad and worse things happen at sea.
« Last Edit: June 04, 2016, 05:46:38 PM by johnr »
New Zealand
Online Vagrant
« Reply #28 on: June 04, 2016, 07:41:35 PM »
I doubt you hurt the new clutch. you know how to ride too well.
I got the old Harley dresser so hot in Gatlinburg  one time it destroyed the resistor plugs. a new set brought it back to life. try new ones. I bet the engine is fine once you find the original problem.
although you'll never hear the end of it put the wife on a bus, leave the trailer at some nice Guzzi guy or dealer there and I bet you can ride it home unloaded. you are demanding a lot from it. again if that TPS has 40000 miles on it $100 spent at the Harley shop might cure it.
it is usually something simple.
« Reply #29 on: June 05, 2016, 06:33:33 AM »
A Guzzi engine is one of the most robust IC engines ever designed. As Pete says, if it hasn't made the "Dogga dogga" noise it's still alive. I wouldn't give up on it yet...
