Author Topic: 1100 sport rear wheel hub  (Read 1661 times)
Offline Rosso Woody
« on: June 02, 2016, 06:09:42 AM »
I am stripping down the rear wheel to paint and wanted some guidance on removing the inner hub where it seems the cush drive is?
David "Woody" Woodward
2023 V100S Mandello
2017 Stelvio
2008 Breva 1200 Sport
2004 V11 Coppa Italia
1997 Sport 1100 ie
1983 SP1000 Rossa Bianca
Re: 1100 sport rear wheel hub
« Reply #1 on: June 02, 2016, 07:15:31 AM »
On the inside, where hub is, there are 6mm bolts that hold a plate in place. Take them out, pry out plate, then a pad ring, then lift the cush drive plate & rubbers. Now the hub w/wheel bearings is exposed. If it is dry, you may need to beat it out.
Offline Rosso Woody
« Reply #2 on: June 02, 2016, 09:08:59 PM »
Yes I am down to the plate with the gear but was hard to get out so did not want to start prying on it. Thought it might be pressed in!
2023 V100S Mandello
2017 Stelvio
1997 Sport 1100 ie
« Reply #3 on: June 02, 2016, 09:28:47 PM »
Flip it over and tap w/rubber mallet, it should move. You may have to wiggle it out gently w/o prying. Not much room to pry it out, no it's not pressed in.
I have one to do myself, for my LM3. Powder coating it black, came off a Centauro.
