Author Topic: Starter-03 EV  (Read 3045 times)
Offline Wild Bill Guzzi
Starter-03 EV
« on: June 02, 2016, 08:37:23 AM »
I need a starter for my 2003 EV.  Is there anything I need to know before I purchase one?  Where is a good source to buy one?
Re: Starter-03 EV
« Reply #1 on: June 02, 2016, 08:43:15 AM »
Online Wayne Orwig
Re: Starter-03 EV
« Reply #2 on: June 02, 2016, 09:09:05 AM »
The original Valeo starter is rebuildable too. Follow that EuroMotoElectrics link for parts.
Re: Starter-03 EV
« Reply #3 on: June 02, 2016, 09:50:05 AM »
Euromoto  electrics is good, I bought a starter and parts to rebuild the Valeo so I could slap one in and have one on the shelf ready
Orange Guzzi
Re: Starter-03 EV
« Reply #4 on: June 02, 2016, 10:58:09 AM »
Clean and grease before you replace it.  The planetary gears are probably greaseless.
Re: Starter-03 EV
« Reply #5 on: June 02, 2016, 12:11:43 PM »
There are valeo and valeo clones.  The clones are awful.
Re: Starter-03 EV
« Reply #6 on: June 02, 2016, 12:44:33 PM »
 I bought one from them few years back and it whines when you first start her up.  Valero Starter
Re: Starter-03 EV
« Reply #7 on: June 02, 2016, 12:50:43 PM »
*shrug* I have one of theirs failing in my 'vert right now.  They don't personally build them.  I don't think we can hold them responsible for failing starters.
Re: Starter-03 EV
« Reply #8 on: June 02, 2016, 01:00:09 PM »
What makes the starter whine?
Re: Starter-03 EV
« Reply #9 on: June 02, 2016, 01:03:25 PM »
bad manners.
Re: Starter-03 EV
« Reply #10 on: June 02, 2016, 01:06:42 PM »
Maybe because the Valeo is a gear-reduction starter?
Online Wayne Orwig
Re: Starter-03 EV
« Reply #11 on: June 02, 2016, 01:20:54 PM »
There is a plate to keep dust out of the magnets (my guess). It is pressed in and I have seen them come loose. Mine has been loose for a year or three. You hear it spin after you release the button. Too lazy to take apart and fix it. Maybe next year.
Re: Starter-03 EV
« Reply #12 on: June 03, 2016, 11:44:51 AM »
  If I do nothing to the starter, what eventually will happen?  I want to be clear on one thing, is the screeching noise coming from the starter gear contacting the flywheel?
Offline Mike Tashjian
Re: Starter-03 EV
« Reply #13 on: June 03, 2016, 02:38:15 PM »
Screeching is usually a lack of lubrication. A good indicator that you should pull it and give it a once over. Mike
Offline pehayes
Re: Starter-03 EV
« Reply #14 on: June 03, 2016, 06:13:20 PM »
Mine screeches in cold weather.  Not so much in warm weather.
98EV
