Author Topic: Norge adjust throttle cables  (Read 1453 times)
Offline atavar
« on: June 05, 2016, 02:04:31 PM »
After replacing the grips on the Norge I adjusted the throttle cables.  It seems to have made a small improvement on the low speed snatchiness. I hope I did it right..
What I did was to first loosen both cables with the adjusters at the grip housing entry.  I then positioned the twist grip to the off throttle stop.  Then I tightened the RETURN cable so it was just taut after which I tightened the PULL cable to remove any slack.
It seems to have worked.  Is there a better method?
BTW, while I was up at The MotoCycle Shop Doug let me know that the new improved drive bushings at both ends of the drive shaft also help with the snatchiness so I ordered those too.
