Author Topic: T3 oil pressure lines to the rocker covers.  (Read 3924 times)
Offline falcone
    • MOTO GUZZI OWNERSHIP - V7 CLASSIC AND BREVA 1100.
« on: June 06, 2016, 05:58:47 PM »
Just fired up my T3 which had a professional rebuild a while back but not had time to put in to service until now. With the rocker covers off, the left hand side seems to have plenty of oil squirting out, the other side in comparison seemingly almost nothing? I took the rockers off and had a look and all seems fine. No blockages anywhere, everything lining up and oil comes up the pressure lines on both sides. How much oil should come out??? Is there a reason for the discrepancy?
V7 Classic 2008
Falcone Turismo 1955
Aero Merlin Morgan Three Wheeler T3 1000cc Engine.
V50 Monza
Triumph 900 Street Twin.
Honda CD200 Benly.
Royal Enfield Classic Trials.
Re: T3 oil pressure lines to the rocker covers.
« Reply #1 on: June 06, 2016, 06:06:01 PM »
Nah, should be similar amounts. Someone hasn't put longer rocker spindle retaining bolts in the LH side have they?
Offline falcone
« Reply #2 on: June 06, 2016, 06:36:53 PM »
Thanks Pete. I doubt it, the professional specialises in Guzzi's and came highly recommended, but probably worth looking at the left hand side. I only took the right hand rockers off to inspect as they were giving out the very little, almost, no oil. I thought they perhaps should be more like the left side and squirting the oil out? How much oil should come out. The left hand was throwing it out so that I soon turned off! This was at barely more than tickover.
V7 Classic 2008
V50 Monza
Honda CD200 Benly.
Offline TOMB
« Reply #3 on: June 06, 2016, 07:00:21 PM »
If its the rubber type lines to the head the inside of the rubber hose may have detereated and the inside is blocked. They come apart easily just pull the hose and it should come off just replace with some oil resistant  hose and see if the flow matches the other side .My friend had the oil pipe blow off while in upstate New Hampshire -fix was a piece of rubber tubing the he carried for repairing a leaking hose on his convert. Just saying
As a side note I replaced the feed lines to the heads with the metal type from a Ambo /Eldo .
This was on my Convert and just bolts on.
Remember that the metal piping goes back to the original V7 so this is a proven system
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline falcone
« Reply #4 on: June 06, 2016, 07:09:24 PM »
Thanks Tomb. No, is the stainless type I have fitted.
V7 Classic 2008
V50 Monza
Honda CD200 Benly.
Online acogoff
« Reply #5 on: June 06, 2016, 07:57:57 PM »
    Also check that there are no chunks of debris inside of the rocker shaft-seen it happen. And teflon lines are the clear shi$$ compared to the rubbery ones of any type, well worth the couple bucks extra.
« Last Edit: June 06, 2016, 07:59:05 PM by acogoff »
Marshall County Minnesota USA
Offline falcone
« Reply #6 on: June 07, 2016, 02:59:01 AM »
Thanks acogoff will definitely look. I am a self confessed worrier when it comes to my bikes. About to go out now and have a look at the l/h rocker assembly.
V7 Classic 2008
V50 Monza
Honda CD200 Benly.
Offline falcone
« Reply #7 on: June 07, 2016, 03:00:07 AM »
Mind you have to be pretty obvious to spot something :-)
V7 Classic 2008
V50 Monza
Honda CD200 Benly.
Offline falcone
« Reply #8 on: June 07, 2016, 09:25:59 AM »
These are pictures when just run for a few moments. They were both clean before hand... Again the l/h has plenty of oil the r/h seemingly nothing?
V7 Classic 2008
V50 Monza
Honda CD200 Benly.
Offline JoeW
    • The Guzzi Doctor
« Reply #9 on: June 07, 2016, 02:51:24 PM »
Pull the rocker shaft retaining bolts, make sure they aren't too long. If they go too deep into the rocker shaft, they'll block the passage. I use a m6x12 with a split lock washer.
Joe Walano
« Reply #10 on: June 07, 2016, 03:21:08 PM »
IMO, 12 mm is just a little too short, 14 mm engages more threads and doesn't block the passage.
Offline JoeW
    • The Guzzi Doctor
« Reply #11 on: June 07, 2016, 03:49:59 PM »
OK but, I think 13mm would be best
This is a 12 mm with a compressed split lock.
Joe Walano
Online acogoff
« Reply #12 on: June 07, 2016, 04:06:41 PM »
     You could pull the banjo and put the hose in a container an run it a bit to get an idea as to how much flow gets there. A hose can go bad or even be bad when new.
Offline falcone
« Reply #13 on: June 07, 2016, 04:13:31 PM »
Many thanks for the suggestions Joe W Antiem Cycles and acogoff. Taking the banjos off and running in to a container is my next step. I'll check the rockers as well. Thanks
V7 Classic 2008
V50 Monza
Honda CD200 Benly.
Offline JoeW
    • The Guzzi Doctor
« Reply #14 on: June 14, 2016, 07:49:29 AM »
Well? What did you find?
Joe Walano
