Author Topic: Cyclops Seat Post NGC  (Read 2243 times)
« on: June 11, 2016, 06:06:52 PM »
A guy in my building has just picked up a Cyclops bicycle, quite a rare beast apparently.
The seat post is frozen in place I think it's an aluminum post in a steel tube.
Any ideas on how he can free it up?
Roy
Re: Cyclops Seat Post NGC
« Reply #1 on: June 11, 2016, 06:25:50 PM »
In the us we have a product called pb blaster, it's a penetrating oil. Used it when I was a wheelchair tech. Chairs are exposed to some corrosive fluids I won't go in to. Usually an overnight soaking did the trick.
« Reply #2 on: June 11, 2016, 06:35:11 PM »
I guess I should have said i think it's a case of dissimilar metals, corrosion.
He can't apply heat, the special paint job is one of the features of this bike.
Online RinkRat II
  • Lake Powell AZ
« Reply #3 on: June 11, 2016, 07:09:13 PM »
 Well  Mr. Roy you can apply heat , just use a hand held hair dryer very carefully. A good penetrant first will no doubt be the ticket.  My personal favorite is a 50/50 mix of laquer thinner and ATF. Also remove the seat and lightly strike the seatpost while heating . Good Luck :popcorn:
    Paul B :boozing:
« Reply #4 on: June 11, 2016, 07:35:20 PM »
I wouldn't get lacquer thinner near a good paint job!
Aluminum expands with heat more than steel, so to get an aluminum seat post unstuck from a steel frame, ideally you'd cool it a lot.  Ice would do some good.  If you could get some dry ice surrounding it for a while, that could really help.
Online BMCMOTO
« Reply #5 on: June 11, 2016, 08:09:05 PM »
Bikeforums.net.
Tons of information and he should be there anyway.  Great source of information on bicycles especially classic light weights.
There are many ways to remove stuck seatposts that will not damage a precious frame, patience is a key ingredient in virtually all of them.  I seriously encourage extensive reading before taking irreversible action.  Ben Franklin said "Experience is a dear school. A fool will learn in no other."  in other words, "do your learning from other's mistakes".
Brian
« Last Edit: June 11, 2016, 08:17:59 PM by bmc5733946 »
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
