Author Topic: Does anyone recognize this front master cylinder?  (Read 2877 times)
Offline leolad
« on: June 13, 2016, 03:52:36 PM »
It had a reservoir where the bolt is but was broken in transit. Previous owner had single Brembo disc installed on '73 Eldo. Thanks for any help you can provide in identifying and or finding a replacement  :grin:
Re: Does anyone recognize this front master cylinder?
« Reply #1 on: June 13, 2016, 04:07:38 PM »
Damn that's an odd angle for a picture.  It makes my brain hurt!
Do you have any better angles?  From that it doesn't look like a guzzi part.  I'm guessing an aftermarket Arlen Ness?  They were common in 1/2" and 5/8" back in the day.  The plate-type attachment is also reminiscent of some weird early brembo hydraulic clutch stuff, but I'm grasping at straws there.
What is the front brake caliper?  It might be easier to steer you toward a workable replacement.  But we need to know what caliper we're working with.
Offline leolad
« Reply #2 on: June 13, 2016, 05:03:53 PM »
Yes it is a Brembo caliper. The MC is attached to the throttle assembly  via a plate as you said.The reservoir was mounted at an angle to the handlebar so I don't think it was a stock setup. Thanks for your help.
« Reply #3 on: June 13, 2016, 06:14:27 PM »
Was the cup directly communicating with the pump, or was it a remote cup with a hose?
Offline leolad
« Reply #4 on: June 14, 2016, 07:12:35 AM »
Yes the reservoir is attached directly to the MC.
Offline Don G
« Reply #5 on: June 14, 2016, 08:43:13 AM »
Looks like it is off of a Brit Bike. Triumph peraps? DonG
« Reply #6 on: June 14, 2016, 08:50:25 AM »
I was gonna say 70's Yamaha? not a Guzzi part.
Offline SPScottNT
« Reply #7 on: June 14, 2016, 09:16:25 AM »
If I am remembering this correctly, the stock disc brake set up on that bike was a single Brembo F08 caliper operated by a Brembo master cylinder with a nominal 15mm (but closer to 16mm) piston and a round reservoir.  That particular m/c was probably optimal for working 2 F08 calipers.  Using it on just a single caliper gave a very wooden feel - I suspect the m/c was changed out with good reason and purpose on the O/P's motor cycle and this may be a case in which returning it to stock is not ideal in terms of brake feel and performance.
If you don't already know this reference, this page and table at Vintage Brake is very useful in picking m/c - caliper combos: http://www.vintagebrake.com/mastercylinder.htm
Scott
Offline Mark Dasher
« Reply #8 on: June 14, 2016, 09:33:49 AM »
That is a master cylinder and switch/throttle assembly from a '79 on Triumph T140 Bonneville.  It has the alloy brake lever and the earlier one has a formed chrome one.
Here's a link for a good photo: http://thebonnevilleshop.com/triumph-t140-tr7-bonneville-1979-on-front-master-cylinder-complete-pn-60-7163/
I'm sure they can help you out with a reservoir cup, if that's all you need.
'75 850T
'78 Robin
'06 Breva 1100
jlburgess
« Reply #9 on: June 14, 2016, 10:15:07 AM »
Well done!  The panel was nearly stumped on that one :bow:
Offline Mark Dasher
« Reply #10 on: June 14, 2016, 11:06:00 AM »
I just happen to be working on one presently!
'75 850T
'78 Robin
'06 Breva 1100
Offline leolad
« Reply #11 on: June 14, 2016, 12:48:35 PM »
Wow, you guys are fantastic. Thanks for your help.
