Author Topic: Oil level on updated Norge dipstick?  (Read 2463 times)
bpreynolds
« on: June 19, 2016, 07:18:30 AM »
The '07 Norge I recently acquired has the updated long dipstick as pictured.  The stick has 2 notches on the bottom.  I assume first notch is low and 2nd is full?
Re: Oil level on updated Norge dipstick?
« Reply #1 on: June 19, 2016, 08:41:53 AM »
You'll know for sure the level w/you change the oil. Should be 3lts and a couple glugs w/filter full. Will be by the top line if marked correctly. Usually top line is full and bottom is add.  Not really familiar w/particular stick.
Offline radlefty
« Reply #2 on: June 19, 2016, 09:08:57 AM »
Yes, your assumption is correct. I had the same dipstick on my 07 Norge.  Use a rag to unscrew it when checking oil. Thing gets bleeping hot.
It's alway's about the journey... Wherever you go, there you are.
Bikeless in Mpls
bpreynolds
« Reply #3 on: June 19, 2016, 09:54:08 AM »
Thanks, Rad.  Now to just get that Beetle map installed.
