Author Topic: Can a lash adjustment effect exhaust pop?  (Read 3086 times)
Online bad Chad
« on: June 20, 2016, 04:23:10 PM »
I have been running with the db killer in my Mistral can for a couple years now, for two reasons.  All the Guru's say it provides better fueling when in, and it stops the off throttle popping I would get without it.  The down side for me is it is darn close to stock quiet.   Since I don't like the popping, off throttle, and I do like the idea of it running the best it can, I left it in.
But a few days ago I just couldn't take it any more, I needed some soul sound, so I took it out, and the result, it ran great with very little popping at all!  The only thing I can think of thats changed is I recently checked the lash, and snugged them up a smidge.  Some were at most a couple thousands over, so I brought them back to book spec.  Could that be the cause?   This is a 2v Breva 1100.  It's by no means too loud, it just has a nice deep rumble, that can actually be heard!
1988 YX600 Radian
Re: Can a lash adjustment effect exhaust pop?
« Reply #1 on: June 20, 2016, 04:44:11 PM »
Yes, but chances are within a few hours it will trim itself lean again and the popping will return.
Offline pressureangle
« Reply #2 on: June 20, 2016, 09:08:49 PM »
Popping in the exhaust is most often a sign of an air leak somewhere in front of the muffler. Unless your EFI completely shuts off fuel, when you close throttle the mix doesn't always light, and the unburned fuel collects in the pipe. Add a little air, hot carbon or fire from a following combustion event and you get a pop.
There are other possibilities, but they all involve fuel and air.
Offline Bisbonian
  • Living the Dream
« Reply #3 on: June 20, 2016, 09:42:15 PM »
This was my experience as well.
Offline lucky phil
« Reply #4 on: June 21, 2016, 07:01:30 AM »
Mechanical issues aside popping ( as opposed to backfiring)is more often than not a sign of a weak mixture. A weak mixture burns slower to the point where its still burning when the exhaust valve opens, hence the popping on the overrun. The more free flowing the exhaust the more pronounced, richening it up a little on closed throttle will usually cure it.
Ciao
« Last Edit: June 21, 2016, 07:02:52 AM by lucky phil »
redrider
« Reply #5 on: June 21, 2016, 07:28:18 AM »
Every one of mine suffered a drop in low rpm grunt when the baffles/killers were removed. They felt a tad stronger in the last 1000 rpm but I do not live there.
« Reply #6 on: June 21, 2016, 10:21:54 AM »
If no air leaks are present in the headpipes, the most common reason for popping on closed throttle overrun is because of a lean idle mixture.
Offline kevdog3019
« Reply #7 on: June 21, 2016, 12:35:21 PM »
I agree with Red with this statement and my results.  There are trade-offs and sound is yet another.
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
redrider
« Reply #8 on: June 21, 2016, 07:26:29 PM »
I did modify the killer for the Benelli. The closed end that faced the incoming exhaust was fly cut open. This really enhanced the quality of sound with no loss down low.(ButtDyno) DynoJet 139hp 93lbft.
