Author Topic: T5 on ebay  (Read 1824 times)
Offline dxhall
T5 on ebay
« on: June 21, 2016, 09:30:42 PM »
There's a very nice T5 on eBay right now.  The contemporary reviews of the bike were pretty negative, calling it a "parts bin special" and criticizing the 16in wheels.  Are they as undesirable as the reviewers said?  I've never seen one in the flesh.
Moto
Re: T5 on ebay
« Reply #1 on: June 21, 2016, 09:41:06 PM »
It is supposed to have inadequate cornering clearance because of the wheels, per Mick Walker's buyer's guide. I've never seen one, so I can't really answer your question. Sure looks clean.
« Last Edit: June 21, 2016, 09:41:47 PM by Moto »
Re: T5 on ebay
« Reply #2 on: June 21, 2016, 10:11:42 PM »
I like mine, but, I am not a cornering fool either.  I've only hit the pegs a few times.  It only has 92k miles on it now.  :)
I kinda like the 16" wheels, except for a slight limitation in tire selection.  The geometry makes the steering very quick, but, once you get used to not putting any pressure on the bars it is nice and stable.  I do keep tire pressures at the 40-42psi range.  Sport Demons are still available for it and work well.
The only real downside is mileage.  It gets the same or worse than the 1000 series bikes of the same era (around 40mpg).  Why?  Maybe cause of the 7/33 rear drive, maybe cause the 850 motor gets flogged more than a 1000 would.  Don't know.  I can still get 200mi before the reserve is hit (gas tank is a bit less than 6gal).
If the suspension has not been messed with you probably want to put in better dampers/springs/shocks and a fork brace if that one doesn't have one.
And they are 'parts bin' bikes.  Check the part on your bike before you order.  Most of the suppliers know the issues and can guide you in that regard.  99% of the parts will fit fine, but, then you get one that is 'different' than the book.
Offline Turin
Re: T5 on ebay
« Reply #3 on: June 21, 2016, 10:16:08 PM »
Lots of guzzis' are parts bin specials. I wouldn't let 16" wheels scare me off. I had a duc with 16" wheels and taller profile tires made it handle beautifully.
1985 Sidlow Guzzi
Re: T5 on ebay
« Reply #4 on: June 22, 2016, 07:18:29 AM »
Yep, many from the 80's have mix and match parts.  But, that is one of the great things about the Tonti bikes.  There is so much that interchanges between models and years.  Like the SPIII fairing that I put on my T5.  Driveline parts. etc.
If you are looking at the red one on ebay...keep in mind the stock seats are like sitting on a slightly padded 2x6.  And they aren't really collectible so the price may be on the high side.  I love the descriptions people use.....Guzzi's version of a cafe bike....roflmao.
« Last Edit: June 22, 2016, 07:33:41 AM by charlie b »
