Author Topic: GuzziDiag on Linux  (Read 17178 times)
Offline tpeever
GuzziDiag on Linux
« on: July 02, 2016, 10:48:33 AM »
Picked up a used university surplus PC laptop running Ubuntu the other day for 40 bucks. Want to use it to run GuzziDiag. Had GuzziDiag running just fine previously on a borrowed Windows XP machine but no luck yet with the Linux laptop. Pretty sure it's a driver issue. Can anyone point me to a set of simple step-by-step instructions on how to get the proper drivers installed? I have the connector cables from LoneLoc. I am reasonably computer literate but have zero experience with Linux. Thanks.
2024 Suzuki V-Strom 800
1979 Kawasaki KZ1000 LTD
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1974 Norton Commando
1968 Moto Guzzi V700
1967 Triumph TR6C
1961 Norton Dominator
Offline rboe
Re: GuzziDiag on Linux
« Reply #1 on: July 02, 2016, 12:31:27 PM »
GuzziDiag comes in a Linux version (and Mac) too.
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
Offline StuCorpe
« Reply #2 on: July 02, 2016, 01:21:07 PM »
Get the Linux version or try loading "Wine" on the Ubuntu machine. This lets you run many (but not all) Windows programs under Ubuntu.
« Reply #3 on: July 02, 2016, 01:53:33 PM »
I could not get it to connect with Ubuntu MATE...I'm sure it was just a port configuration issue....took the easy way out an borrowed my wife's Windoze machine...
beetle
« Reply #4 on: July 02, 2016, 05:43:06 PM »
You don't need to install any drivers for Linux.
With the cable plugged in and powered, check that you have this device:  /dev/tts/USB0
In a terminal, as root, run this command:
chmod 666 /dev/tts/USB0
Create a symlink:
 ln -s /dev/tts/USB0 /dev/ttyUSB0
Even with superuser privileges, make sure you are part of the dialout group:
usermod -a -G dialout root
usermod -a -G dialout <your user name>
That should do it.
Offline tpeever
« Reply #5 on: July 02, 2016, 08:08:21 PM »
I could forget about Linux and install Windows but wanted to see if I could get it to run in Linux first
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1967 Triumph TR6C
Offline tpeever
« Reply #6 on: July 02, 2016, 08:13:04 PM »
Create a symlink:
That should do it.
Thanks beetle. Can you put this in a format that I can understand what I need to do, step-by-step. As I said, I am brand new to Linux and do not know how to check if I have a "device", what a "superuser" is, what "dialout" is, how to open a terminal etc. Thanks. Sorry if I seem a bit dense.
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1967 Triumph TR6C
Offline tpeever
« Reply #7 on: July 02, 2016, 08:16:53 PM »
Thanks. I do have the Linux version installed but can't get it to recognize the bikes ECU. Could go the Windows emulator route change operating system to Windows but wanted to see if I could run GuzziDiag in Linux first
« Last Edit: July 02, 2016, 08:18:50 PM by tpeever »
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1967 Triumph TR6C
beetle
« Reply #8 on: July 02, 2016, 09:39:17 PM »
I'll try to make this as simple as possible. OK. First thing to do is open a terminal window. Ways to do this vary by which type of desktop you have, but you can usually right-click on the desktop and the menu will have a Terminal or Open-In-Terminal selection. Alternatively, type CTRL-ALT-T and a terminal will open.
You will get something that looks like this:
Plug in the GuzziDiag cable to a USB port. In the terminal, type:
Code: [Select]
sudo usermod -a -G dialout <your user name> [enter]
You will be asked for your password. Enter your password and hit [enter].
Then, type:
Code: [Select]
ls -al /dev/ttyUSB0
You should get something like this:
That should do it. You should now be able to connect.
Offline tpeever
« Reply #9 on: July 02, 2016, 10:49:19 PM »
Thanks Mark! Will give it a shot
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1967 Triumph TR6C
beetle
« Reply #10 on: July 02, 2016, 10:52:57 PM »
If you can't connect immediately, try rebooting.
« Reply #11 on: July 03, 2016, 12:53:32 AM »
mark@cunnox?
(Snort!)  :grin:
beetle
« Reply #12 on: July 03, 2016, 01:21:41 AM »
:laugh:
Offline tpeever
« Reply #13 on: July 13, 2016, 08:58:33 AM »
Thanks very much Mark! Worked great!
1978 Moto Guzzi T3
1978 Kawasaki KZ650
1976 BMW R75/6
1975 Honda XL250
1967 Triumph TR6C
Offline MorenoB
« Reply #14 on: September 19, 2016, 06:53:12 AM »
I'm experiencing many issues with my XP laptop (i can connect 1 on 10 times)...Considering that I've also a Debian Linux OS in my EEEPC I'll try the linux version! Many thanks for this short guide :-)
Moto
« Reply #15 on: September 19, 2016, 08:42:09 AM »
Works fine on my Eee PC, FYI.
Moto
Offline MorenoB
« Reply #16 on: September 28, 2016, 07:36:13 AM »
YEHA"I't works very fine also on my Debian based EeePC  :thumb: Perfect!
Offline webmost
  • Safety Third
    • The Sotweed Factor
« Reply #17 on: September 28, 2016, 11:28:11 AM »
help a newb out here....
What years & models does this work on?
Unmitigated risk aversion is the new Puritanism; complete with witch hunts funny outfits and humorless preachers thundering doom. The Deity is Safety; Satan is a Lawyer; but the object is the same: to suck the life out of life and tell you how to live it.
« Reply #18 on: September 28, 2016, 11:56:48 AM »
Don't bother trying to run it under Wine, you'll never get the communications working.
Either use Windows or, run the native Linux version.
You need to make sure you have the drivers working for the RS232-USB adapter that you have.
Get one that uses the FTDI chipset.  It is more modern, and works better.   Also, most Linux distributions have the driver built in for it.
Offline waxi
« Reply #19 on: September 29, 2016, 05:46:54 AM »
GuzziDiag should also work on Raspberry Pi. Will try to do that one day... with touchscreen. I am looking for master thesis title anyway :thumb: Any ideas?  :huh:
« Last Edit: September 29, 2016, 07:16:39 AM by waxi »
Moto Guzzi Nevada, 1998
« Reply #20 on: September 30, 2016, 05:01:40 PM »
What programming language is GuzziDiag written in?   Maybe port it to Android?
That would be the ultimate in portability!
« Reply #21 on: September 30, 2016, 08:49:54 PM »
15M, 15M-RC, W5AM and MUIG3.
beetle
« Reply #22 on: September 30, 2016, 10:41:23 PM »
An ARM version is not available yet. The developer did mention to me he will compile an ARM version once the language he uses has been developed for the ARM architecture.
« Reply #23 on: October 01, 2016, 06:27:28 AM »
Do you know what language it is written in?    There are many Android tablets that have Intel Atom (x86) processors, so, it might be possible to do an Android build, although, it may only work on x86 targets.    I only bring up Android in the context of your ARM comment, because many Android devices have ARM processors.
Android uses Java as it's primary development language, but, it is also possible to compile libraries in C and C++ and integrate into apps.
I've got a  26 years of software development experience, much of that embedded systems.   I've also got a couple years worth of iOS and Android experience, albeit, most of that using Cordova, which is Javascript+HTML5 based.
beetle
« Reply #24 on: October 01, 2016, 06:39:58 AM »
No, I didn't ask.
