Author Topic: Guzzidaz Help  (Read 3300 times)
Offline old head
Guzzidaz Help
« on: July 04, 2016, 11:29:58 AM »
ok,
I order the cables from LonElec, installed the drivers.
96 Breva 1100 stock setup
downloaed guzzidag VO.46
 IAW5xwriter VO.21
IAW5x Reader VO.24
hooked it up and no joy.  I got the red triangle on the dash and the service warning on the dash?
I am also using a Shorai battery.  It cranks fine, drove it this morning.  When I disconnected everything it would not crank, shows three codes in dash errors under M, 1, 2, 3.  then I pulled and checked the fuses, and the relays, no change. started disconecting the battery and the service triangle went away and it fired right up.
I have the blue led on the cable, only have one port.  checked device manager, and it says
 USB serial port com3
 manufacturer FTDI
the device is working properly
Driver tab
driver provider  FTDI
date                3/9/2016
driver version 2.12.16.0
Running windows 10 on a touchscreen laptop
I only tried the reader, it comes on when I click it and when I hit read it asks where to save it, but nothing it isn't reading anything.
I have it in neutral, side stand down, tried recycling the key, reconnected everything a couple of times nothing.
stumped.....
Anyone have ideas?
Anyone done this that lives in SE Louisiana that would like to show me how to do it.
Old HEad
tried it again, same result, only this time the battery shows 12.8 volts on the dash, but won't crank again after hooking everything back up again.  hooked up the charger on 2amp trickle and it shows the battery with only 25% charge, weird..
« Last Edit: July 04, 2016, 11:53:28 AM by old head »
06 Breva 1100
Hepco-Becker crash bars
Givi A620 screen
Garmin GPS
Re: Guzzidaz Help
« Reply #1 on: July 04, 2016, 02:05:32 PM »
I'm questioning the battery.
Thinly disguised bump to the top so someone that knows will tell you what's wrong.. :smiley:
Offline old head
Re: Guzzidaz Help
« Reply #2 on: July 04, 2016, 02:32:25 PM »
I hooked up a brand new battery from my boat to be sure there was sufficient juice,  No change still got the service triangle and no crank.  Dash does its dance fuel pump pressurized.
So I pulled and tested every fuse, all good.
resented every  relay I could find, no change.
Battery shows 13 volts and charger indicates full charge.
started checking every connector all tight, except the MPH startus interruptus connection.  It pulled apart, pushed it back togeher and the service tirangle went away and it fired right up.  Weird, as I have never had an issue with the setup since I installed it years ago.
Anyway, it cranks and no service triangle now.
IT is really weird, but at any rate it is running.
tried again later, turned off my anti virus, and wifi. restarted pc.
hooked it up again, LED light on, hooked to pc, turned key on no indication that it is connected
opened guzzidag, says Breva 1100 disconnected.
Still any ideas as to why it won't connect.
Old Head
« Last Edit: July 04, 2016, 05:08:33 PM by old head »
06 Breva 1100
Givi A620 screen
Garmin GPS
Online Wayne Orwig
Re: Guzzidaz Help
« Reply #3 on: July 04, 2016, 07:41:18 PM »
Ignoring the READER and WRITER at the moment. Does GuzziDiag alone work? Did you download and try the AdapterTest?
If those work, you know that the reader and writer do NOT work at the same time as GuzziDiag? (only one program at a time can talk to the cable)
Offline drdwb
    • backfeelsgreat.com
Re: Guzzidaz Help
« Reply #4 on: July 04, 2016, 07:57:59 PM »
For my Breva I had to use com port 4 which is sllected with a drop down box where you are reading com port 3 in preferences.
Offline old head
Re: Guzzidaz Help
« Reply #5 on: July 04, 2016, 08:31:42 PM »
ok,
I found an adapter test clicky from Beetle  :bow: :bow: ran it all is good now.
4th try seemed to be the trick.  finally go it to connect and save the OEM file to my computer.
next writer started but the battery died about halfway into the upload.
hooked up a charger and restarted the upload and it says done, whew!!!!
started Guzziday, reset the tps and learned parameters, so should be good to go
battery only shows 7.5 volts, so clearly something is amiss here.  Its a Shorai battery, it has been working fine in the warmer weather, don't ask it to start if below 60\
At any rate, it is on a charger now and we will see what happens after it is charged.
this is the second battery from Shorai, first one they replaced under warranty, I won't go back again.  the battery just doesn't perform when the battery is cool.  I will go with a AGM sealed battery I guess, same as OEM.
At any rate, I think everything is good at this point, can't wait to try out the programs that I got from Paul and Beetle.
Old Head
06 Breva 1100
Givi A620 screen
Garmin GPS
Online Wayne Orwig
Re: Guzzidaz Help
« Reply #6 on: July 04, 2016, 10:44:46 PM »
Having the battery drop out during a write can permanently kill the ECU. Always safest to have a charger attached during a write.
Offline pauldaytona
    • Paul's fast Guzzi Page
Re: Guzzidaz Help
« Reply #7 on: July 05, 2016, 02:30:40 AM »
 The ecu can't get locked when a write fails. With other programs maybe but not with guzzidiag. Why? before writing the old map is erased, but not all of it, the communication program stays always, so you can always restart writing. |It's correct that the bike won't work after a failed write, but can allways write again. Starting writing with a bad battery without chanrger connected is not the best idea.
Bad batterys are always a thing to solve first.
Paul
Daytona 1225, Stelvio 1151
beetle
Re: Guzzidaz Help
« Reply #8 on: July 05, 2016, 03:05:24 AM »
What Paul said.
I have tried to deliberately brick an ECU while using the GuzziDiag tools. Not going to happen.
Re: Guzzidaz Help
« Reply #9 on: July 05, 2016, 06:27:11 AM »
Not even I, the archetype of gurning Neanderthal, am able to brick an ECU using Guzzidiag. I've even managed to 'Un Brick' a couple that had had failed PADS writes! I'm not clever enough to know why but the customers were happy!
Online Wayne Orwig
Re: Guzzidaz Help
« Reply #10 on: July 05, 2016, 07:25:20 AM »
That is good to know.
But still sounds like something to avoid.
Offline old head
Re: Guzzidaz Help
« Reply #11 on: July 05, 2016, 07:40:38 AM »
had I known the battery was weak, I would have done that.   It is a weird thing, as I rode it that morning to church and back, never gave me an indication that it was that weak.
At any rate, it has been on the charger overnight, and we will see what happens shortly.
thanks for all the input
Old Head
06 Breva 1100
Givi A620 screen
Garmin GPS
Offline old head
Re: Guzzidaz Help
« Reply #12 on: July 05, 2016, 08:30:21 AM »
went outside, battery fully charged, so says the trickle charger.
disconnected everything and it fired right up
it seemed to idle better than before and even started faster, maybe just my imagination but a ride is next on the list.  however, I have drawings piling up in my inbox to do from the weekend so the ride will have to wait.
Old Head
06 Breva 1100
Givi A620 screen
Garmin GPS
