what are the differences between swingarms and rear drives? (g5 and lemans 1)
Topic: what are the differences between swingarms and rear drives? (g5 and lemans 1) (Read 1934 times)
amamet
July 09, 2016, 12:52:02 PM »
well, while working on my 77 lemans and 78 g5, i put both swingarms with the rear drives (still attached) on the same shelf. you guessed it, now i don't remember which was which. any tell tales signs i should look for?
thx
allen
charlie b
Re: what are the differences between swingarms and rear drives? (g5 and lemans 1)
Reply #1 on:
July 09, 2016, 03:47:07 PM »
Do you have a copy of Guzzilogy? There is a longish section on different rear drives.
TOMB
Reply #2 on:
July 12, 2016, 06:27:02 PM »
Lay them side by side and compare. I think the only difference is the bearing dia. for the u joint, I know or sure the G5 had the larger hole in the bearing-- up to that point the bearing was similar to the T3,smaller hole for the bearing--it was a ongoing change over at the factory at that time to the larger u joint.
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
1976 CONVERT-62000 MILES AND BUILDING
MGNOC # 2723
Reply #3 on:
July 12, 2016, 06:43:57 PM »
Having not been in the same situation. What kind of difference would it make? If it was a Convert involved instead I'd understand that there's a difference. "Jus' askin."
Last Edit: July 12, 2016, 06:44:39 PM by Tom
From the Deep Deep South out in left field. There are no stupid questions. There are however stupid people asking questions. 🤣, this includes me. 😉 Hawaii.
TOMB
Reply #4 on:
July 12, 2016, 07:49:49 PM »
The bearng in the convert swingarm is the large type same as a G5 the only difference is the convert universal joint the back part is the drive shaft with a G5 is A Separate Peace other than that there should be no differences
TOMB
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
Reply #5 on:
July 12, 2016, 08:01:20 PM »
Finish might be slightly different on the two arms. I thought the LM had a satin finish whereas the 'Tourer' series had gloss black? Apart from that they are identical.
