Author Topic: New toy for the shop  (Read 1670 times)
« on: July 11, 2016, 08:49:25 PM »
I sold off my Lincoln Easy Mig 280 and Miller Ac/Dc Thunderbolt stick welder for this new ESAB Rebel 3 in one unit.
This is a 110/220V MIG / TIG / Stick
The easy to follow chart inside the side cover tells you what to set the digital controls to for wire speed, voltage and amperage, you can store the MIG settings and recall them latter.
Wow! is it easy to use, I welded two thickness of steel pipe to steel washers, followed the settings, turned on the unit and it welded without splatter, with deep penetration, no fuss at all!
A little bit of grinding and the weld is done.
Looking forqard to trying out the TIG, I bought the foot pedal for TIG welding.
For stick weldiong the digital display promts you for the rod type and diameter and the thickness of the steel you are welding.
It also takes a spool gun for aluminum.
It comes with a 110V patch cord, a Victor regulator and Tweco Tog Gun and rod holder.
These have been selling out as fast as dealers can get them on the shelf, I waited two months to get mine.
This is a lot of welder for under $2K and a 2 year warranty.
Offline Don G
Re: New toy for the shop
« Reply #1 on: July 12, 2016, 12:54:35 PM »
Where did you buy that critter? DonG
« Reply #2 on: July 12, 2016, 12:59:23 PM »
KMS tools in Edmonton but OxyPro has all the accessories for less.
« Reply #3 on: July 12, 2016, 02:53:54 PM »
Looks similar to my Boc (rebranded Kempai) 175. I see yours has more hp.  being a 215. Sounds as though the electronics in yours have made a quantum leap as well.
I am really happy with mine. So far I have only used the stick but it is beautiful to use. I have decided to go the disposable 2.2kg gas with mini regulator for the Tig. Already have  CO2 bottle for the Mig but need an adapter.
That chart on the side looks useful! :thumb:
Offline Dofin
« Reply #4 on: July 13, 2016, 08:02:30 AM »
Oh my, Man toys!!!  Saw those on Spike Power Block Truck Tech and Off Road shows.  VERY impressive and Pricey but worth it!!!  You can do any kind of welding with that bugger.
76' Yamaha RD400
76' Suzuki GT500
89' Honda PC800
15' Guzzi V7 Stone
