I wonder if anyone would like to comment?I reversed the forks on my G5 cafe racer and mounted 4 pot Brembo calipers. Brakes are great and retain the original M/C and linked system.At the time I noticed steering was effected with a slight reluctance to turn before dropping in slightly unnervingly. I put this down to squared off tyres. Steering head bearings are good and properly adjusted.I changed the tyres (correct 110/90 rear and 100/90 front Avons) and if anything, the issue is slightly more pronounced.Discs are heavier - HMB floating.So I put the original Brembo P08s back on and hey presto some improvement.However I think I will try front mounting them again to see waht happens.I wonder if the practice of front mounting the calipers on 70s Tonti bikes was actually using their their best position and that the change to rear mounting was really an asthaetic decision.
If you can feel the theoretical differing effect of the front/rear caliper position on a bike like a Guzzi that steers like an ocean liner I'd be truly amazed and suspect you should be racing in MotoGP.Ciao
this is why I never run more than one front rotor and caliper on a guzzi. unecessary, and heavy. Also get some nice EBC floating rotors with aluminum centers. Much lighter. I have the 4 piston caliper on my eldovert behind the fork leg because the caliper is made to go behind. That is the pistons are different sizes, and the pad will wear tapered if you put it on backwards.
Good read. We all were told decades ago that moving the calipers to the rear reduced "unsprung weight". Not being an engineer or physicist, I interpret that as hitting a bump and the suspension is forced to push the mass of the caliper, along with the rest of the wheel upwards as opposed to lifting the caliper mass when positioned behind the fork leg. Compared to the total mass of the front assembly, the mass of the calipers is miniscule. Lots of variables. What else can I learn? Enlighten me.
If something gives way under hard braking and a caliper tries to come loose, having it rear mounted might allow it to jam in place instead of rotating around the disk and ripping loose, but that's an unlikely scenario.
I did some digging and unsprung weight is the weight of suspension components, wheels, tires and brakes not supported by the suspension proper. The chassis, engine and such are sprung. They are isolated from the unsprung weight by the springs. I do remember reading the road tests years ago where it was explained that unsprung weight was reduced by moving the calipers. Hogwash is my conclusion. Another case of some-one making an unsubstantiated claim and having that claim interpreted as fact and thus entering the book of common but not necessarily true knowledge. After all, Journalists throw words at paper. Truth is not always included.
As stated by another, it is reduction in moment of inertia. Moving weight closer to centerline of steering stem...
