Nice, I should have seen it in your signature.I had an old VB and a 500 twin, I forget the model No The mag sprocket turns at half engine speed, if you mounted a strong magnet on the sprocket so it was close to the cover you might be able to pick up a reed switch on the outside, no need to drill holes in the case.It would be fairly easy to try out the concept anyway.If the pickup works it could be adapted to any electronic tacho, 1 pulse per engine revolution.Oopps, I should have said non ferrous bracket, Aluminum or brass, copper are fine.BTW are the old plunger oil pumps still operating, still have a dry sump lube system?
I run a Westach directly off the "P" lead on Mouser. It needs a small fuse in case the tach grounds out.. that would shut off the ignition. You can also use an inductive pickup on a non shielded plug wire.
Here's a magneto to tach converter..https://www.amazon.com/Auto-Meter-9117-Tachometer-Adapter/dp/B00063068W/ref=sr_1_11?ie=UTF8&qid=1468969757&sr=8-11&keywords=magneto+tachometer
That's the Ariel timing cover! It would be a simple setup, but wouldn't the radio interference cause problems pickup (Reed switch?) or with the wires to the gauge?
I don't think so, there's not a lot of energy floating around the mag, besides the reed switch wires could be shielded if necessary.I'll test it out over the weekend using a piece of 1/8" aluminum in place of the timing coverI was at JD also with my Green V11 Sport at the back fence.
Oh, that was you, I often think we should have name badges with our handle on for the rallies.No, I don't have any Ariels here, Corry who you must have met has several nice Velos.The Red Hunter has always been my favorite.
Looked up Westberg Westach. They do some interesting things - instructions to mount to a Ducati for example. I should call them.Is the "P" lead the points lead? The silly Lucas facecam mag has rotating points and all the connections are made internally so no easy way to pull a signal off the points that I can figure out. As for the inductive pick-up, that's what was on a little digital tach, but revving the engine sent it into paroxysms of apoplexy. Smiths has an inductive pickup tach, but it requires the use of resistor sparkplug caps which apparently should not be used with magneto ignitions.Chuck, enjoyed meeting you at John Day!
The sketch I posted earlier will work, I found the reed switch is easily activated through 1/8" aluminum up to 1" away by a small magnetI ran it at 2700 RPM the equivalent of 5400 for the Ariel and got a nice square pulse.http://s1304.photobucket.com/user/Kiwi_Roy/slideshow/Tach%20Pickup
