Author Topic: installing a swingarm w/ drive box in a Tonti frame  (Read 10665 times)
Offline Rusnak_322
« on: July 20, 2016, 08:15:46 AM »
Is this possible?
Do I need to remove the drive box to ease installation?
I have been looking at the G5 workshop manual from thisoldtractor.com and it looks like it is supposed to be installed as a unit. But I have been having issues getting it to line up. the swingarm is very tight to the frame. So much so, that I had to scrape off the new paint on the frame (it wasn't that thick). and I still have a hard time getting into place. I can get one side in (opposite of the drive box) but then the thing is cocked and I cant get the other side in.
Plus, it seems like it is ridiculously difficult to line up the driveshaft splines to the motor and the assembly is pretty heavy.
Also, by looking at the service manual I cannot tell if I were to remove the drive box, will I have to drain the gear oil and then re-shim when I put it back together?
2007 Ducati Monster S4Rs
Re: installing a swingarm w/ drive box in a Tonti frame
« Reply #1 on: July 20, 2016, 08:28:08 AM »
Take off the drive.  You need to be able to turn the drive shaft to align the splines.
Then llook at the frame where you are putting the forward end of the swing arm.  The are slots in the frame.  If you angle the tail downward the pivot tube slips up those slots and into position very naturally.
Some folks remove the lower of thos frame bolts holding the rear of the bottom rails on to help with the space problem.  Inserting should be a 30sec operation when that  downangle is right and the slots are used.
Remember that the swing arm needs to be properly aligned or you sideload your u-joints.
Offline Rusnak_322
« Reply #2 on: July 20, 2016, 08:43:54 AM »
thanks,
Will I need to drain the box prior to removing it?
I did unbolt the lower frame rails, I thought they were pulling the frame in (they weren't)
Offline wymple
« Reply #3 on: July 20, 2016, 09:23:53 AM »
I got mine on. The coupling on the shaft, and pressed up as far as I could go did not want to line up to slide on. Pull the plug wires to kill the ignition and bump the starter for the rotation necessary. Popped right in. I fought with it for an hour before giving up and doing that.
Offline Rusnak_322
« Reply #4 on: July 20, 2016, 09:27:09 AM »
unfortunately, I have a little way to go before I start hitting the starter button.  :grin:
« Reply #5 on: July 20, 2016, 09:49:59 AM »
Take off the drive. Keep the splined end pointing up and you won't lose any fluid.
You need to lube the splines in there anyway.
Offline nc43bsa
« Reply #6 on: July 20, 2016, 12:57:57 PM »
I'll be doing that this week.
What is the preferred spline lube?
1990 MilleGT
Offline Two Checks
« Reply #7 on: July 20, 2016, 01:42:32 PM »
I use CV joint grease or Moly Lube.
1987 1000 SPII "Il Duce' II"
Offline v7john
    • The Racing Rhino
« Reply #8 on: July 20, 2016, 02:43:59 PM »
Take the drive box off. The reduced weight makes it easier to get the swing arm on and the UJ splines lined up.
Remember when refitting the drive box to leave fully tightening the 4 nuts holding it to the swing arm till the rear wheel axle has been lined up.
1954 BSA M33 500cc.
Offline Rich A
« Reply #9 on: July 20, 2016, 02:49:11 PM »
Someone, I think MG Cycle, sells the stuff. Sticky as snot.
Rich A
Offline Rusnak_322
« Reply #10 on: July 20, 2016, 02:54:58 PM »
I just read up on this today. Good tip. Make sure the rear axel slides out without any resistance when the bolts are tight.
« Reply #11 on: July 20, 2016, 03:53:33 PM »
Like many things, everyone has their own preference. This is mine:
Offline Rusnak_322
« Reply #12 on: July 20, 2016, 09:47:11 PM »
Got it in, had a hard time getting it off the swingarm, the bearing box part stayed with the swingarm.
Now I have to find the article with the tips about adjusting the swing arm stub spindles that I came across last week but forgot to bookmark.
« Reply #13 on: July 20, 2016, 10:02:11 PM »
just count the exposed threads on the pivot pins and make them equal.. I'm more worried about the "bearing box", so the the pinion gear came out of the rear drive? it needs to be sync'd proper to the crown gear.. right Pete?
« Reply #14 on: July 20, 2016, 11:58:34 PM »
 :1: on all the advice given.  :thumb:
Offline Rusnak_322
« Reply #15 on: July 21, 2016, 10:20:11 AM »
are you talking about setting the crown / piston clearance?  - like on page 94 of the pdf (page 92 of the service manual)
http://www.thisoldtractor.com/mg_manuals/workshop_manual_g5_sp.pdf
I wouldn't think that it was altered by removing the bearing box
« Reply #16 on: July 21, 2016, 10:38:35 AM »
maybe but I'm unsure what the "bearing box" is in your post.
Offline twhitaker
« Reply #17 on: July 21, 2016, 10:39:14 AM »
True.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
« Reply #18 on: July 21, 2016, 10:43:26 AM »
 I am also curious what a "bearing box" is .
Offline twhitaker
« Reply #19 on: July 21, 2016, 10:46:40 AM »
I think it's the part that houses the pinion and bearings.
MGNOC-11168
Dayton, OH
Offline Rusnak_322
« Reply #20 on: July 21, 2016, 11:07:54 AM »
Sorry, this is my second bike with a shaft drive (I also have a PW50)
I confused Drive Box and Bearing housing. What I am talking about is "E" below.
Online Chuck in Indiana
« Reply #21 on: July 21, 2016, 01:00:05 PM »
No, he's talking about the swing arm bearing pins.
« Reply #22 on: July 21, 2016, 01:10:08 PM »
If the pinion assembly (E) stayed on the swingarm, That means it likely IS rusted to the driveshaft and coupler. Try to get it off of there and gooped up to save the splines.
On the swingarm pins, just count the threads on each side. Turn them in to remove all play.
Offline Rusnak_322
« Reply #23 on: July 21, 2016, 02:49:06 PM »
It came off with the swingarm, but I was able to get it to move about 1/16". After it came off, I didn't see any reason to pull it off.
I don't think that anything on this bike is rusted. The back story of this bike (from the seller) is that a older Guzzi enthusiast had a stroke and put this bike together with spare parts he had as a kind of physical therapy. The guy I bought it off, got it from his estate. He only wanted to buy one of the bikes, a Ducati, but the family wanted to sell the duck with two Moto Guzzi's as a set. The other Guzzi was a race bike. I wonder if he was a member here at one time??
I have never had a bike come apart so easy, and I used to take 1 year old street bikes and turn them into race bikes! I bet that there was 4 lbs of copper never seize on here. Everything with threads seems to have it, except the 4 bolts coming out of the drive box, they have what looks like blue loc-tight.
« Reply #24 on: July 21, 2016, 07:51:02 PM »
There are O-rings at either side if the bearing carrier.  Also, the carrier has only one correct orientation when you reinstall it.  Don't get it wrong.
I may be overpicky about the swingarm alignment, but if you thin so, I don't want to hear about it.  this is my swingarm alignment method:
screw in the pivot pins and check them with the depth post on your dial indicator.  If you don't have a dial indicator --- PULEEZE!  Tweak until they are exact AND the swingarm binds (doesn't drop freely).  Then a slight turn back -- just a nudge -- on both pins until the swingarm drops freely from any angle but has no 'looseness' when you rattle it -- much like setting up a steering head.
As I've said before, sideloading the ujoint causes premature wear of all sorts of things like the ujoints, carrier and tranny shaft bearings, etc.  So I take it very seriously.  ymmv, and/or some folks don't care. $0.02, etc.
« Reply #25 on: July 22, 2016, 06:50:02 AM »
I use depth mics. Don't have depth mics? PULEEZE!  :grin: :grin:
But I take it seriously, too, although I think a guy with a good eye, 10X magnifier and machinist's scale could get it close enough.
Offline mtiberio
    • TiberioRacing
« Reply #26 on: July 22, 2016, 07:02:33 AM »
side to side equality is not critical on a big block guzzi with a double (CV) u-joint. On small blocks with their single knuckle joints, yes, the output shaft must be co-planar with the driveshaft. On big blocks, you can use the swingarm pins to move the swingarm right or left as needed. When I raced, I offset the rear wheel to the left (relative to the rear drive unit) so that fatter tires wouldn't rub against the swingarm. To bring the tire back into alignment with the front, I would then shift the whole swingarm to the right via the swing arm pins.
assuming that equal amounts of the swing arm pins showing means that the output shaft and driveshaft are co-planar is a big assumption.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline Rusnak_322
« Reply #27 on: July 22, 2016, 08:16:42 AM »
When you say you offset the rear wheel to the left, do you mean that when you built the spoked wheel that you purposely offset the rim from the hub? OR did you use a spacer?
« Reply #28 on: July 22, 2016, 08:49:36 AM »
Agreed. After all the frame is just a big weldment with all the warping that involves. Still.. I try to do the best I can to center it.
« Reply #29 on: July 22, 2016, 09:09:38 AM »
When you put the rear drive assembly on, tighten the axel before tightening the four nuts on the front of the pinion housing. It's in the manual to do it that way,case you doubt it
