Author Topic: NGC Drive Chain slap. NGC  (Read 2430 times)
« on: July 20, 2016, 08:33:30 PM »
Miss my shaft drive after I see this.. is it normal for a chain to slap around like this?
https://www.youtube.com/watch?v=cxkszWGICD8&feature=youtu.be
I have the slack pretty close to what the book calls for..
Offline nc43bsa
Re: NGC Drive Chain slap. NGC
« Reply #1 on: July 21, 2016, 03:10:24 AM »
From what I've seen in the past, yes, it's fairly common, especially on long-travel swingarms.
1990 MilleGT
Offline Perazzimx14
« Reply #2 on: July 21, 2016, 05:12:12 AM »
Normal.
Offline ken farr
« Reply #3 on: July 21, 2016, 11:07:48 AM »
WOW.
I have never seen that perspective before, nor have I looked.. :rolleyes:
Is the chain actually making contact with the swing arm at times ????
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Offline Bisbonian
  • Living the Dream
« Reply #4 on: July 21, 2016, 11:50:56 AM »
WOW.
kjf
There are plastic guides on the swing arm, they need to be replaced occasionally as the chain wears grooves in them. If let go long enough, I've seen pictures of grooves worn through and into the swing arm.
Offline Perazzimx14
« Reply #5 on: July 21, 2016, 11:57:54 AM »
« Reply #6 on: July 21, 2016, 12:00:21 PM »
that was cool! thx 4 posting.
Offline lucky phil
« Reply #7 on: July 21, 2016, 04:30:34 PM »
It looks like the bike is a 650 single and unless you know how fast it was being ridden and importantly on or off the throttle its hard to say. On the throttle the upper chain run is tight and the lower is where the slack is. Assuming the bike is on the gas and not being lugged along then I'd put my money on a chain with a tight spot in it. fairly common on a chain tha'ts done a lot of miles. It shouldn't be like that though with a decent chain and ridden sensibly.
Ciao
« Last Edit: July 21, 2016, 04:31:43 PM by lucky phil »
