Author Topic: Technical comic relief  (Read 4736 times)
Rough Edge racing
« on: July 25, 2016, 07:34:13 AM »
 The dual 650 Triumph engine land speed racing bike I've been building is nearly finished. Built from a pile of parts ,many cannibalized from Suzuki and Harley....Two 1956 Triumph 650 engines that will make about 65 HP each@7300 ...Harley 5 speed trans, clutch and electric starter. Custom made frame ,ZR rated radial tires...The exhaust is just for looks, I just started fabricating the real pipes.
 1350 CC gas push rod records are from 150-172 MPH at the various tracks...
  Here I'm demonstrating the electric start feature. The front engine left cylinder fires 5 degrees before the left rear cylinder so it's like a 1300cc Triumph so to speak... Most LSR bikes and all vintage LSR bikes require a hand held remote starter...I want the rider to be able to push a button, just like a street bike,  :wink:  The engine have compression...
      https://www.youtube.com/watch?v=vNbs--dBGr4
« Last Edit: July 25, 2016, 07:36:01 AM by Rough Edge racing »
Offline Xlratr
Re: Technical comic relief
« Reply #1 on: July 25, 2016, 09:55:00 AM »
Very very cool!  :cool:
Offline Petrus Rocks
« Reply #2 on: July 25, 2016, 01:48:44 PM »
It's a wonderful experience in the flesh! :thumb:
« Reply #3 on: July 25, 2016, 02:16:15 PM »
Very nice, but you scared me right at the end when your smile disappeared suddenly.   :laugh:
Rough Edge racing
« Reply #4 on: July 25, 2016, 04:04:21 PM »
  My wife shot the video and said it appeared I took a knife in the back at the end of the video....We did about 6 takes because we got distracted by laughing..Might have caused a nervous tic or I'm really strange........... :grin:
Offline balvenie
« Reply #5 on: July 25, 2016, 06:56:37 PM »
Please Sir; I want More :grin:
Oz
04 Cali
Rough Edge racing
« Reply #6 on: July 25, 2016, 07:14:49 PM »
   Home built offset sprocket
   Building the primary drive using modified Triumph and Harley parts
       Aligning the parts....
     What the air sees....
« Last Edit: July 25, 2016, 07:17:57 PM by Rough Edge racing »
Offline 80CX100
« Reply #7 on: July 25, 2016, 08:03:58 PM »
Wow, some amazing fabricating skills went into that,,, beauty!
Kelly
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Offline Rick4003
« Reply #8 on: July 25, 2016, 08:22:44 PM »
Very cool project!
How do you keep all your primary chains tight? It must rattle like crazy if they don't have some chain guides or something :grin:
More pictures please! :grin: Always nice to see the ideas and solutions that's going in to a build like this!
What kind of speeds are you aiming at with the bike?
-Ulrik
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
Offline arveno
    • ddleathers.com
« Last Edit: July 25, 2016, 09:14:05 PM by arveno »
« Reply #10 on: July 25, 2016, 09:18:52 PM »
Looks like some serious fun.  :thumb:
Offline balvenie
« Reply #11 on: July 25, 2016, 10:44:02 PM »
Mr. Rough Edge racing,
Thankyou very much, that was great :thumb: :thumb:
"Aligning the parts"       I'll bet that was.............str essful :grin:
Oz
04 Cali
« Reply #12 on: July 25, 2016, 11:39:21 PM »
 Jim , what kind of internal components are you installing ? I'm a bit out of the loop on Triumphs these days . Running Hepolite pistons , maybe old JoMo cam profiles , or something more modern . What about primary balance , 70% range maybe ? Connecting rods  , the OEM rods were pretty good , but sustained 7300 RPM's might strain them . Valve sizes , guides ? Supposedly the engines in The Gyronaut were producing 70 HP apiece , but Leppan had a good size budget .
« Reply #13 on: July 26, 2016, 12:15:16 AM »
Amazing bit of work!
Just curious -- why primary chain rather than belts?
« Reply #14 on: July 26, 2016, 01:13:18 AM »
I dips me lid!
Rough Edge racing
« Reply #15 on: July 26, 2016, 05:19:12 AM »
 Dusty, it's Tony,lol....The engines have nitrided stock 1960's cranks, MAP forged steel connecting rods, 10.5 forged piston with a tight quench, Kibblewhile valves and beehive springs, Smith bros  steel push rods, Web camshafts, mild head reworking, Mikuni 34 MM flatslide carbs...Leppan's engines were 750's on alcohol...For his best runs they ran on 80 percent nitromethane and made about 100 HP each. My engines are a bit conservative for reliability ...
 I chose chains because I understand them and they cost a lot less than belts and custom pulleys...The second naked bike in LSR history to break 200 mph was a dual engine Triumph in 1970. My chain drive is a very similar design to that bike...There will be a chain guard as required by the rules
  I discussed the bikes with Kyle of LowBrow Customs... Being a bike shop his bike is also advertisement and a show machine and looks it . My goal was a machine built primarily with hand held tools and an old lathe by a retired electrician in a typical home shop There were no plans other than mental pictures..
  The actual cost of parts and engine machine work is about 15,000 bucks. My rider pays for 90 percent, I provide all the free labor... :grin:
 A few years back we bought the 85 Guzzi California to build it into a 160 mph naked frame LSR bike...There are several running that fast....But my rider persuaded me to build a two engine Triumph powered bike....There's an attraction to these antique lumps...
Online chuck peterson
« Reply #16 on: July 26, 2016, 06:34:56 AM »
What a proud papa... :weiner:
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Rough Edge racing
« Reply #17 on: July 26, 2016, 08:48:34 AM »
  Yeah, twins  :grin:   The 50's engine cases are pretty much the same as when the engine was introduced in 1938 as a 25 hp 500 cc twin...And in 1983 when Triumph ceased production the head and internal parts used the same 1930's technology... Just like the wide spaced valves and deep hemi chamber on Guzzis , Ducati bevel twins and pre Evo Harleys...
« Reply #18 on: July 26, 2016, 08:53:36 AM »
I don't know how you can get anything done without being able to spit on the floor and walls.
« Reply #19 on: July 26, 2016, 10:27:24 AM »
 Are you sure it isn't Jim ? :laugh: Sad part , I know it is Tony , may be overwhelmed by the sight of a home built Triumph powered ground shaker  :bow:
 Thanks for the specs , and the chain primary makes sense on this type of bike , being capable of handling high power in a fairly compact package . Not like this bike is gonna do touring duty  :laugh:
Offline Xlratr
« Reply #20 on: July 26, 2016, 02:23:46 PM »
Are the two engines set up identically or does the rear have different fuel requirements? This is a great thread, I hope you can keep it updated!   :thumb:
« Last Edit: July 26, 2016, 05:10:24 PM by Xlratr »
Rough Edge racing
« Reply #21 on: July 26, 2016, 04:51:13 PM »
Are the two engines set up identically or does the rear have different fuel requirements? This is a great thread, I hope you can keep it updated!  :weiner:
  The rear engine  has .0005 inch more cylinder to piston clearance than the front....The rear possibly having a different fueling requirement is an interesting question... ...The basic tuning will be similar to my successful single 650 Triumph LSR bike. The guys who ran these combos in their 50's-60's heyday say very little, same for the very few running them now... I'm literally on my own with tuning and design...Back to the fueling, perhaps the "concealed" rear engine might want to be jetted a touch richer for it's cooling effect...it's all a guess...
