Use Dremel to cut bolt in narrow spot?
Topic: Use Dremel to cut bolt in narrow spot? (Read 2376 times)
Nic in Western NYS
July 26, 2016, 03:06:30 PM »
I'm swapping license plates and need to remove a stripped bolt. Anyone use dremel tools for this? Any concerns about sparks so far away from the tank? No open fuel canisters in the garage, I'll be wearing face and hand protection. Anything else to look out for? Thanks for fielding this basic question.
'04 Ducati ST4sABS
John A
No way to slow down...
Re: Use Dremel to cut bolt in narrow spot?
Reply #1 on:
July 26, 2016, 03:12:40 PM »
should be ok, Id cover the bike with a sheet, Id use a reinforced cutter wheel, you can get a thinner cut with the non-reinforced wheel but they are very fragile.
Waterbottle
Reply #2 on:
July 26, 2016, 03:13:23 PM »
You might want to Tape up any bits that the sparks produced will hit, Rags socked in water are Good protection too. hold the screw head with a pair of vice-grips if you have them
2015 Griso SE Rosso
2012 Stelvio 8V
2009 Griso R Track only
76 GT 750 Suzuki
rodekyll
Not my real name
Reply #3 on:
July 26, 2016, 03:25:20 PM »
I don't think a dremel is going to produce enough swarf to amount to anything. I'd slot a piece of cardboard to tuck around it if you're concerned, but I wouldn't get real meticulous about it.
Reply #4 on:
July 26, 2016, 03:27:14 PM »
Tape works too if'n you don't have cardboard. Let the wheel do the work. Don't put too much pressure on it while cutting.
From the Deep Deep South out in left field. There are no stupid questions. There are however stupid people asking questions. 🤣, this includes me. 😉 Hawaii.
Nic in Western NYS
Reply #5 on:
July 26, 2016, 03:44:04 PM »
Much appreciated!
'04 Ducati ST4sABS
Sasquatch Jim
Sidecar - Best drive by shooting vehicle ever
Reply #6 on:
July 26, 2016, 06:49:07 PM »
If you can get one of those suits the army uses when disarming I.E.D.s , wear that.
And give the fire department a heads up before you begin.
Last Edit: July 26, 2016, 06:50:13 PM by Sasquatch Jim
Sasquatch Jim Humanoid, sort of.
fotoguzzi
vee git tooh soon oldt und too late wise -my Dad
Reply #7 on:
July 26, 2016, 06:52:55 PM »
wear safety glasses! my nephew is an eye doc.. once a week he has to pull some metal swarf out of someones eyeball.
lucian
Reply #8 on:
July 26, 2016, 07:06:17 PM »
A soft small dia. bolt like that you should be able to just lock onto it it on both sides with vise grips and twist it in half.
ITSec
Reply #9 on:
July 26, 2016, 07:58:31 PM »
Slip a piece of that thin metallic-faced insulation around the workspace - it's cheap and works great as a spark/swarf shield.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
