Author Topic: Going Tubeless.  (Read 3894 times)
Going Tubeless.
« on: July 29, 2016, 02:26:29 PM »
Re: Going Tubeless.
« Reply #1 on: July 29, 2016, 02:32:40 PM »
5 paragraphs into the first sentence of the description I gave up on trying to understand wtf they're selling.  Fer goddesses sake -- buy a vowel!   :coffee:
Re: Going Tubeless.
« Reply #2 on: July 29, 2016, 03:14:08 PM »
I need to reread.  Thanks.  They also need better sentence structure.  :grin:
« Last Edit: July 29, 2016, 03:17:59 PM by Tom »
Offline Sheepdog
Re: Going Tubeless.
« Reply #3 on: July 29, 2016, 03:17:14 PM »
I was interested when they first came out, but the originals were sized only for off-road bikes. A road going version was promised, but I never heard about them being offered for sale. The original seemed pretty cool. The dirt bike versions worked as advertised...
Re: Going Tubeless.
« Reply #4 on: July 29, 2016, 04:14:50 PM »
yeah, does anyone have experience ?  do you need two valve stem holes in the rim?
Re: Going Tubeless.
« Reply #5 on: July 29, 2016, 04:48:20 PM »
The rim size looks okay but widths that are advertised don't look like they'd work for our road bikes.  :undecided:
Offline cloudbase
Re: Going Tubeless.
« Reply #6 on: July 29, 2016, 06:19:08 PM »
"Instant bolt on performance"
Re: Going Tubeless.
« Reply #7 on: July 29, 2016, 06:27:34 PM »
For off-road use only.
Re: Going Tubeless.
« Reply #8 on: July 29, 2016, 06:43:45 PM »
I went tubeless on my 72 Eldorado, I had a bit of trouble sealing the spoke holes until I realized I was using the wrong silicone
Just because it can be done - do it
« Last Edit: July 29, 2016, 06:48:07 PM by Kiwi_Roy »
Re: Going Tubeless.
« Reply #9 on: July 29, 2016, 06:53:01 PM »
No thanks.
Offline NWrider
Re: Going Tubeless.
« Reply #10 on: July 30, 2016, 07:45:47 AM »
I've sealed the rear rim on my Triumph XCX using a 3M tape product.   Used sticky paper dots to cover the spoke nipples and then applied the 2" tape.   There are several ways to do this -- mine hasn't dropped a pound of air since I did this.
There's a thread on AdvRider here: http://advrider.com/index.php?threads/tiger-800xc-tubeless-converts.845718/page-13#post-30005204
Offline Lesman
Re: Going Tubeless.
« Reply #11 on: July 31, 2016, 06:39:53 PM »
Super easy to go tubeless. I spent $15+/- per wheel. E6000 or Marine 2100? both great products. E6000 is 1/3 the cost.
Offline Thirtyaughtsix
Re: Going Tubeless.
« Reply #12 on: August 01, 2016, 04:30:59 AM »
What can be done for the valve stem? I'd like to do this one day for my T if possible
2019 V7 III Stone " Murci "
1975 850T " Guzziaughtsix "
Offline kmartin
Re: Going Tubeless.
« Reply #13 on: August 04, 2016, 04:27:20 PM »
Yes, 2 stems.  Mixed results with off road buddies.  It allows extremely low tire pressures for better traction while eliminating pinch flats because there is no tube to pinch.
Keith Martin
Re: Going Tubeless.
« Reply #14 on: August 04, 2016, 05:49:37 PM »
If you are referring to mine, just one tubeless stem,
The secret to success is getting a silicone that sticks well to the Aluminum rim
Re: Going Tubeless.
« Reply #15 on: August 04, 2016, 06:55:13 PM »
http://wildguzzi.com/forum/index.php?topic=85085.0
since then I decided I can do it myself (on my DR rear the front rim does not have the safety bead) with 3M sticky tape.. next tire change..
« Last Edit: August 04, 2016, 06:58:51 PM by fotoguzzi »
Re: Going Tubeless.
« Reply #16 on: August 04, 2016, 07:08:00 PM »
I doubt any old bike has a safety bead however the chances of loosing all your air are no greater than with a puncture.
I had several, flats on my Eldorado usually overnight due to the poor quality silicone but it always held air long enough to get me home. I have a friend an old dirt biker who does all his bikes this way including a 46 Indian Chief.
According to a Google search the safety bead is designed to stop the tire leaving the rim if it goes flat, What stops it leaving the rim without a bead if the tube goes flat?
« Last Edit: August 04, 2016, 07:20:18 PM by Kiwi_Roy »
Re: Going Tubeless.
« Reply #17 on: August 04, 2016, 07:58:34 PM »
I don't know.. just some of the reading I did discouraged doing on the front DR rim.. I might still do it, once I see what inside of rim structure looks like..
I like the 3M sealing tape idea over the silicone tho..  saw another convincing video but I can't find it now..
