Author Topic: breva 1100 error 45 - FIXED  (Read 2446 times)
Offline tris
« on: August 01, 2016, 02:15:24 PM »
Hi
My B11 has just throw up and error 45 code :sad:
Any suggestions as to how to track the problem down??
« Last Edit: August 02, 2016, 01:31:07 PM by tris »
1993 TW125 "POS" - Resting
Re: breva 1100 error 45
« Reply #1 on: August 01, 2016, 04:48:47 PM »
Hi
Can't help you track the problem, but in the event you don't have the decoder page for all the errors, here's what it says about code 45.
45: Error relay starter C.C. ground ECU45.
Probably not much help to you, but it may keep someone else from having to look it up.  I don't recall if I found this info under B11 or 12S information.  I think they both use the same ECU
Offline tris
« Reply #2 on: August 02, 2016, 12:19:48 AM »
Cheers - I'd found that but didn't know what it meant!!
I've since found a thread that says it refers to the starter relay so that's where I'll start
Offline tris
Re: breva 1100 error 45 - FIXED
« Reply #3 on: August 02, 2016, 01:33:55 PM »
FIXED
If you accidentally pull one of your plug and play startus interuptus connector plugs apart you get an error 45
Whoops  :embarrassed: :embarrassed:
« Reply #4 on: August 02, 2016, 02:53:11 PM »
A .45?  Sounds like a heckofa prize for so little work.   :laugh:
Offline tris
« Reply #5 on: August 03, 2016, 01:41:06 AM »
 :grin:
As a Brit - if I got handed a .45 the best thing I could do would be to throw it at the would-be assailant - I probably shoot myself otherwise  :wink:
